converting 2900 >2800 oil gallery plug |
Author | ||||||
Beirnesy ![]() Orange Level ![]() ![]() Joined: 30 Jun 2012 Location: Mid Western Ont Points: 351 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Dec 2018 at 8:09pm |
When removing the oil cooler from a 2900 to have the oil pass through the galleries in the block you must remove a spring and an oil gallery plug. How do you remove internal plug ?
Edited by Beirnesy - 12 Dec 2018 at 8:11pm |
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Sponsored Links | ||||||
Make a plug to fit loose in bore with center hole the size of long drill bit. Slide plug in block to center dill. Drill old plug and hope drill catches plug enough to pull it out. MACK
