Combine header stand
spencefarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spencefarm Quote  Post ReplyReply Direct Link To This Post Topic: Combine header stand
    Posted: 24 Jun 2017 at 6:47pm
So I'm wanting to build some sort of header stand for 13 ft grain platform and a 438 corn head. What are some thoughts oon how I go about this?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 9:32pm
RR tie on the ground boar two holes and bury 4x4 s vertically let them stick up 6" above the RR tie. Boar two more holes about 8' apart bury 4x4s leaving a foot above the top of the RR tie bolt a 6x6 to each side for the cross support. You'll need to measure the dimensions from your header mounted on your combine to get the height correct. If the front of the header is to high you won't be able to back out from the header.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 10:13pm
we never used them on the grain heads,, too easy to warp the head and destroy it... always sat them on a couple of old truck tires... header stands ok on slick level concrete floor... but who....
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 5:18am
all my headers had their own stands, but you had to have something under them or they would sink into the dirt. later on I just set down 2 posts with a 4x4 across the front of them and set the front of the headers on that. pallets stacked 2 high will work too. my IH headers would sit direct on the ground, but I never did that as they would rust a lot doing that. I always tried to keep air flow under any headers I took off combines.
acjwb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acjwb Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 8:14am
With old wagon frames so cheap, make brackets and use them for the heads. You could move them easy if you need to. This could be done about as easy.
