Combine + Grain cart = TRIBINE
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Topic: Combine + Grain cart = TRIBINE
    Posted: 17 hours 27 minutes ago at 7:16pm
Around the year of 1997, a man from Logansport, Indiana had an idea to increase harvesting capacity and decrease harvesting labor requirements. His concept was basically a combine that pulled a 1,000 bushel hopper directly behind it.  The machine was articulated to be able to steer, where the tail of the harvester connected to the front of the 1000 bushel cart. As I understand it, from 1997 to around 2012, he built three prototype machines. Each new machine (I'm sure) incorporated new ideas and benefits to his dream futuristic combine. The goal was to have 1,000 bushels in the hopper and unload into a semi-trailer in 2 minutes and then right back to harvesting. This concept harvester eliminated a tractor, 350 bushel dump cart and an operator, to catch grain on-the-go and then dump into the semi trailer. I first became aware of it in late 2012 or early 2013, when he had just built the fourth prototype machine, using a Gleaner S-77 combine platform !!  Man, I was all in over this !!!!! The most radical design change in harvesting since WW2 (according to him) was now working in fields of wheat, corn and soybeans and it was a GLEANER platform he chose to build his concept machine with !!   I know little to nothing about the three previous proto's, but by now the TRIBINE had large drive tires in all four corners and was true 4-wheel drive. The steering was mainly articulated at the tail of the harvestor and front of the grain cart. It also had crab steer at each of the four king pins (for getting close to a truck) and compound steering (for sharper turns on the end of the fields). Well, apparently the GLEANER platform wasn't going to cut it capacity wise, as a Class 7. I'm sure he was getting lots of interested parties calling him and suggesting what it would take for them to purchase one of his new harvesters. So, from 2013 with GLEANER S-77 (at 370 HP) to a totally new design by 2016, with a 38 inch diameter axial rotor with TWO engines, totaling around 650 HP !!   Well, the other machinery manufacturers were watching and re-thinking their position in the harvesting markets as the TRIBINE kept morphing itself into a larger and different machine. Today, everyone's unloader system is about double the BPM, shortening unload time, and grain tank capacity is also larger. Many of the large grain carts you can buy now are waaay more than 1,000 bushels and 1500 bushels is becoming more common every season.  Where am I going with this ??   Think about the hundreds of farm equipment manufacturers from 100 or more years ago, who didn't make it.    I believe in my lifetime, I have witnessed the beginning, the struggle to make it somehow someway work, and in the end, it didn't.  I watched a brave man with a dream bet everything, and I don't think it has turned out well. I admire those who have more guts than I've ever had to follow their dream.  Google: Tribine Harvesters and there is tons of information on this subject.
Edited by DrAllis - 17 hours 10 minutes ago at 7:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 46 minutes ago at 7:57pm
I remember seeing the Tri-bine at the Farm Progress Show a couple different times.  I to was impressed that he chose the Gleaner platform for the base combine.  Andy
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 36 minutes ago at 8:07pm
I had forgotten about this concept.  I'm not clear if they're still building any.  Saw this thing at a Farm Equip. Show in KC Mo. when it was being introduced.  You can bet the Big Boys have not lended any support and probably done what they could to quash the idea.  There is another monster machine from Europe out there making some test runs.  Again, not sure what happened to it.  From what I recall it was a transit nightmare.  Probably another example of a good idea with not enough financing for the long-term battle.  Dr., thanks for the reminder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 22 minutes ago at 8:21pm
I just don't see where they are doing anything these days. The last public comments on anything from the owner was Oct, 2021.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 52 minutes ago at 8:51pm
Didn't someone in Indiana buy the Bi-rotor on tracks and was going to try and make it into a production machine?  Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 42 minutes ago at 9:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 37 minutes ago at 9:06pm
That European machine/system was called Nexat out of Germany.  It was undergoing testing here as late as 2024.  Not sure if anything happened after that.  Google has some information on it and there are videos. It's a beast.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 27 minutes ago at 9:16pm
I believe the Bi-rotor was purchased by John Deere and shelved. While it had some interesting features (like a rotating 360 degree cage/concave) it would have never matched the capacity of today's class 9-10 or 11 machines.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 11 minutes ago at 9:32pm
Yes, both Tribine and Nexat were interesting machines and I followed them for quite a bit.
Since then I saw the Brazil "agro never sleeps" guys and they think the whole US fascination with grain carts is absurd. I see their point.
They buy a second combine instead of the cart+tractor. Same labor. They park the semi at the headland, combine down field until half full, turn and combine back next to the section they just combined so they know the yield/field is the same and get full just as they are at the semi and unload. Even though they are idle unloading, the second combine doing the same allows them to combine at 189% of a single combine and cart system.
Plus they have a backup combine if either goes down.
A recent set of videos on grain bag systems revealed a few operators avoiding the semi truck labor and excessive long weight traffic at the elevator. Specialized bag fill and empty machines.
So I expect the next big idea in combines will be onboard large grain bags that get dropped like round bales or long beans, with two typical hoppers in them. Or round bale size to handle with skid steers.
Almost like the old days of AC All-Crop combines with bagger chutes instead of a bin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 59 minutes ago at 10:44pm
When I run my brother's combine (6-30) in corn, depending on the field, I may take one round of 6 rows and a second round of 3 or 4 rows to end up with a full tank to dump. The field dictates what works, with waterways and row length. I have one long contour field where I take 4 rows down and back and have a full tank. The goal is to have as many bushels as possible before unloading. He plants 12-30's so I can do this. The negatives?? Over time and enough acres it will wear the center rows out faster on the corn head, but I'm not always the driver, so this isn't an issue (yet).
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 36 minutes ago at 6:07am
Years ago, Uni-Harvester(New Idea) had a combine that had an additional unloading auger straight out the back of the machine. We would pull a gravity box behind, and unload on the go. Worked great especially when ‘opening up a field’.
I too, have always thought the grain cart usage is absurd, we would just park trucks/gravity wagons at the end of the field, then the combine would stop and unload into them. We would occasionally unload on the go, with just a gravity box pulled by a Farmall M, or a 400.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 15 minutes ago at 6:28am
Shoot lars, my grandfather had that on his 66. But it wasn't supported correctly and it bowed
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 59 minutes ago at 7:44am
Been 60 years ago, but we had a neighbor also pull a wagon behind his ALL-CROP 66 powered by an Oliver.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 39 minutes ago at 8:04am
Here carts work well.  You can't get a loaded semi in & out of many fields and if you could, it wouldn't be in the right place.  In wet conditions it stays on the road.  Unloading on the go saves time although you need more manpower & equip.  There may be some that don't use them, but most do and that proves the point.  Usage may vary by locale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 8 minutes ago at 9:35am
Been know to deadhead in road gear to other end and pick 3 throughs to end up full at truck. That's if I'm working alone. Grain cart is handy with help.
Edited by SteveM C/IL - 3 hours 5 minutes ago at 9:38am
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 31 minutes ago at 10:12am
INteresting concept but seem slike it owuld be extremely heavy in wet fields and not very nimble in small field. WOuld work well in larger drier fields.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 8 minutes ago at 11:35am
Interesting how many new ideas are just old things recycled. On the west coast where combines got a head start on the Midwest. I believe it has to do with weather that help the early combines. Up until the 1940's grain on the west coast was bagged on the combine. Local warehouses were set up to store bags no bulk bins.Wink A bit before my time, but being in a family that had a large combine by 1912, lots of talk of combining. Combines had 16 to 20 foot headers out here from the beginning. Of course yields where not what they are today. And they had side leveling almost from the beginning.
My dad talked of bag shortages during WW2. Partly because jute to make burlap bags was imported, and shortages of labor to make them.
Some very interesting ways of moving bagged grain in the Pacific Northwest. With pictures and story's of trams taking it down cliffs to rivers below.
From the beginning of this thread how big of a machine is too big.
But something about the old is new again fascinates me. In the early 1960's my dad was spending 3 plus months out with John Deere 36b combine pulled with Cat D6 as a custom cutter all within 60 miles of home. A much different harvest window than most of you get. But the JD dealer figured he should get a good candidate to buy a new JD 95H. One of the big selling points the new combine had no draper to worry about with the auger header on the self propelled  combines. Today draper headers are the latest and greatest again.
Ermm From 1970 until 2016 I was involved in grain harvest. From 79 to 85 working for family with 3 to 5 Gleaner MH2's in the field. But nobody had a grain cart or did any unloading on the go. I know of several that had a grain cart, but was temporary storage as they had one truck to haul grain rather than 2. So idea of all the benefits or short comings of grain carts.
Thanks for letting me ramble.......................about the good old days. Wink My be it should just be the old days.
