Combine chain rollers/guides
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Topic: Combine chain rollers/guides
    Posted: 13 Sep 2016 at 10:51pm
Is it OK to replace the metal and wooden chain tensioner wedges with flat rollers? I had some chain issues today and had some cornhead rollers laying around so i put them on and ran it. So far so good but I have to wonder why they didn't from the factory. What is the purpose of a wooden wedge.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 10:55pm
less wear on the chain is why they had wooden wedges. when mine wore out, I replaced them with the little steel pulleys with the sides on them. not much wear cuz they turn with the chain.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 7:08am
When a ball bearing roller type tightener gives out, you are done until you get a new one. Wooden tighteners are not like that. They just don't lock up or fall apart like the others and they will last a long time. My L2 has poly ones that are the same shape as the wooden ones and so far so good.
Wink
I am a Russian Bot
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 9:50am
I replaced all of mine like Lonn with plastic from SI Distributors
