Coil spring bottoms out |
3rd generation
Topic: Coil spring bottoms outPosted: 12 hours 43 minutes ago at 12:31pm |
Allis c coil spring with shock. I’m 210lbs and this spring bottoms out. What’s my solution?
Coil over shock absorber to gain more tension or is a newer coil spring stiffer. |
Posted: 3 hours 20 minutes ago at 9:54pm |
A new shock/spring assembly will be better than what you have. That's what coil springs do over time......flatten out. If it has an slot adjustment, move it as far to the rear as possible.
Edited by DrAllis - 3 hours 7 minutes ago at 10:07pm |
