Clutch Problem on D 17? |
holmesd ![]() Bronze Level ![]() Joined: 05 Aug 2012 Points: 11 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Aug 2012 at 4:41pm |
I have a 1958 D 17, it has been running fine. I hooked up my brush hog to the PTO and was cutting away when it decided to slow down and not move both the tractor and the PTO. Here is what I have, a tractor that when in gear will not move and the PTO will not spin. When I take it out of gear and put it in netural and let the clutch out the PTO will spin, no problem. When I leave it out of gear and move the hand clutch to high or low the PTO will slow down some but continue to spin. Any suggestions on what I have going on?
jlogli ![]() Orange Level ![]() Joined: 12 Oct 2011 Location: Stockport, IA Points: 862 |
Sound like the clutch is slipping. |
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Dnoym N. S. Can. ![]() Orange Level Access ![]() ![]() Joined: 03 Oct 2009 Points: 544 |
what do you mean when you say?
When I leave it out of gear and move the hand clutch to high or low B:-) Dnoym |
The gear box is in neutral and my high /low lever is also in neutral. I then move the high/low lever into either high or low but leave the gear box in neutral.
Any idea on the cost to have the clutch replaced?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21910 |
$250 to $500 for parts depending on what you need and where you buy them. Four to six hrs labor @ whatever the hourly rate is.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
If it's slippin that bad, you might need a different flywheel. My 45 slipped on me while mowing with a Brady flail copper a few times and the flywheel had heat cracks all the way thru and 3 or 4 inches out from the middle.
D-17_Dave ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
Might try to adjust the clutch rod linkage. It may be worn enough to be holding the clutch down.
Yea, I can fix that.....
