Clutch Job on D-14
mherndon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mherndon Quote  Post ReplyReply Direct Link To This Post Topic: Clutch Job on D-14
    Posted: 18 May 2012 at 9:39am
I plan on taking the flywheel off to have it turned when I split the tractor to remove clutch.  What are the torque specs for the following?  Flywheel, pressure plate, and any other torques I might run into putting it back together?
Mark
D-15, Old dealer in Smithville, TN
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 12:06pm
http://www.imperialsupplies.com/pdf/A_FastenerTorqueCharts.pdf
You can look the bolt size up in this chart.
JeffMOnt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 12:28pm
Torque specs for flywheel is 75 Ft-lbs.  Not sure on the pressure plate torque, but as Charlie stated you can look it up on the chart.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 10:02pm
presure plate is 17-20 ft lbs.
you can't always go by a universal chart. The spec in the book for a 3/8"  head bolt on a G is 55 ft lbs. You will not find that on a bolt spec chart. Bob
Edited by Chalmersbob - 18 May 2012 at 10:02pm
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 2:59am
Opps. I just cranked the bolts down on my d14 flywheel
