Close call this morning (pics) |
jjpetrich ![]() Silver Level ![]() ![]() Joined: 06 Sep 2011 Location: Marshall, MN Points: 137 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Jan 2012 at 4:26pm |
Edited by jjpetrich - 06 Jan 2012 at 4:45pm |
On the farm wd,wd45,180,200,7020,8010,8050,f,L2,2 b engines
Me and dad hauled up corn this morning with the 8010, 8050 and my set of wagons a pin weld broke. Had about two feet before the wagon would of pulled the tractor and wagons down into a 30ft creek. Happy God looked out for me on that one!
Edited by jjpetrich - 06 Jan 2012 at 4:46pm |
Dipstick In ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Remington, In. Points: 8602 |
Woof!, bet that was sure enough scary. Glad it worked in your favor.
Dean/MN ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Oak Grove, MN Points: 740 |
Glad it turned out alright for you. My brother has 2- 450 bu wagons and last year he had one full one behind the 8070 with a new 1 1/4" grade 8 pin that broke as he was backing it in the shed. He will never again pull 2 full wagons together again.
HD16,917H,185,7050,8030FWA,8050FWA
beeman ![]() Orange Level ![]() ![]() Joined: 02 Jan 2011 Location: Alabama Points: 230 |
Might put a little extra in the collection plate this Sunday.....just a thought.
1949 B 3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
jhid ![]() Orange Level ![]() ![]() Joined: 31 Mar 2011 Location: Breslau,Ontario Points: 439 |
my boss was pulling a wagon with 200 bales on out of the barn with the forks and he had to back down a bit of a hill with a curve and as soon as he cut to go around the curve the front end started sliding, I was in the barn and heard him yell, it slid about 2 feet but he thought it was going through the shed. I guess it was a day of close calls
red and green are nice for christmas, but orange is all year round
http://www.canadianantiquetractor.com/tractorforum/ |
allischalmerguy ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Deep River, IA Points: 2893 |
So glad and thank God you are OK!
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Kinda like older PTO equipment; those wagons were probably not meant for a 130-180HP tractor. Can't see what that 8000 series is, but they got a looooooooot more pull to 'em than the older say 190's that were the "big" tractors when those were built. Just means you got to inspect things more often for stress cracks. Really glad things turned out ok for you, and hope your posting helps someone else avoid an actual disaster.
Still in use:
Thats the thing i would have noticed that there was a crack or something but theres a plate over where you could see it. Going to make sure to over haul all the wagon gears with new bearings and grease.
cwhit ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Sigel IL Points: 995 |
jjpetrich, do you pull those wagons with a PS ? That jolt between gears can be hard on wagon bolsters. Had the same thing happen to me.
Jordan(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Celina, OH Points: 1564 |
Had to be a bad pin. 1-1/4 inch pin will take all a 8070 can give it and then some all day long. |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Should take 178,000 lbs. to shear an 1 1/4 grade 8 bolt. |
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3866 |
Thanks for the reminder to think twice about everything we do,
KenBWisc ![]() Orange Level ![]() Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1184 |
Had somethiong similar happen. The tie rod bracket brake free of the spindle. Makes you think.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Bolivar Boy ![]() Orange Level ![]() Joined: 27 Dec 2011 Location: wooster, ohio Points: 641 |
what about those planter wheels up against the mail box post?
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1925 |
Years ago a guys wife was hauling to the local elevator with tractor and 2 wagons 500bu in front and 250 behind, when she scaled in and got probed she was waiting for the second wagon and they told her there was non. They hauled 6 to 8 miles, about 1/2 mile along river, they went back looking and after two trips buy saw it flipped in the river with the tires at water level.
Its not the actuall pin that broke but there is a weld on top and on bottom and the top weld wore through and the play broke the bottom which allowed it to slip through. Fixed it this afternoon and went through all bearings and should be good for a couple years.
Pretty sure the one wheel is off a 4 row AC planter and the heavier one is off a rake...not sure.
