Choke cable or rod on d17 carb? |
boscoe ![]() Silver Level ![]() ![]() Joined: 23 Jan 2010 Location: ND Points: 165 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Feb 2010 at 10:17pm |
1959 D 17 I am not sure how the original way of operating the choke, when I got it the cable or rod was gone. I have a cable but not sure how it is originally set up. I can make a bracket to make it work but would like to do it original , carb is original. thanks
Would anyone know of a picture of how it is set up? pictures are easyer to explain sometimes. anything will help
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7505 |
1959 would use a rod to activate the choke. Runs from the carb and comes out the shield under the gas tank.
Dans 7080 ![]() Orange Level ![]() Joined: 05 Feb 2010 Points: 1146 |
I have a 59 D17, it is a rod it attaches to the engine side of the carb, and extends to the left side panel below the gas tank. There should be a slit about 3-8in wide and about 2in long that the rod will stick through with a screw on ball. I do not have any way of taking or posting pics so im no help there.
My 1958 D14 is the same set up - the knob to the right of the decal. ![]() |
Got it i will maybe have to make one. Does anyone have any side panels for a D 17 like the one on the D14, I need a set.thanks
Is that rod 2 pieces? That looks just like the shut off on a D17D. The diesel shut off is 2 pieces anyway.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21907 |
Gas choke rod is one-piece and on all D17's prior to series 3.
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
You can obtain aftermarket side panels from Norm or Doc's Equipment. There may be other suppliers who advertise on this site who can also provide them.
RGR(TX) ![]() Bronze Level ![]() ![]() Joined: 02 Oct 2009 Location: TX Points: 23 |
I HAVE A ROD FOR A D17 GAS.WOULD YOU LIKE A PICTURE OF IT OR DO YOU WANT TO BUY IT? $25.00 PLUS UPS
I made a bracket and hitched a choke cable that I already had up to choke on carb and it works really good I put the choke control in the light switch hole(clutch side) and moved the light switch to the brakes side. I have a bad habit of revising and retooling different parts on equipment, sometimes it works and sometimes not. Thanks anyway.
norm [ind] ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |
we have choke rod and the side panels both 1-800-254-3116 for ordering visa--master cards
alan1959 ![]() Bronze Level ![]() ![]() Joined: 15 May 2016 Location: Avoca, Michigan Points: 22 |
Could you send me a picture of the choke rod off the D17 Allis? Thanks so much!
