Charging 8V battery
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Topic: Charging 8V battery
    Posted: 26 Jan 2026 at 4:05pm
My friend dropped off an 8V battery out of a 1946 Ford that someone had installed. What is best way to try to charge this? I have several chargers but nothing 8V. I think the battery is no good. I will check voltage of it first and go from there. Thx.
Edited by Ed (Ont) - 26 Jan 2026 at 9:37pm
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2026 at 4:13pm
You should be able to charge it with a 12-volt charger on the lowest setting, without hurting anything.
Several battery chargers had a single setting for "12-volt low - 6-volt fast charge".
Edited by WF owner - 26 Jan 2026 at 4:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2026 at 4:19pm
and if you have a volt meter, connect it across the terminals and monitor as the battery is being charged with the 12v charger..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2026 at 5:01pm
Thanks guys! Smile
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 10 minutes ago at 4:21pm
I was just talking to my starter and alternator repair shop a few days ago and got on the subject of 8 volt batteries in 6 volt systems.  In short, they DON'T work!  The maximum output of a 6 volt generator is only 7.2 volts, so the 8 volt battery will never get fully charged, instead it keeps draining.
A 6 volt battery with a 6 volt electrical system that actually WORKS is a far better choice - a good working generator and very thick battery cables.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 5 minutes ago at 6:26pm
Actually, they work well enough that Allis-Chalmers offered it as standard equipment on the W226 Power Units.
It is a simple matter to adjust the Third-Brush type generators to properly charge an 8 Volt battery, my late Father-in-law ran his WD this way for decades with no ill effects.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 58 minutes ago at 6:33pm
a 6 volt generator NOT CONNECTED TO A BATTERY, will put out about 14 volts... A 12 v generator NOT CONNECTED TO A BATTERY will put out 28 volts... I have measured that several times....... The BATTERY is the SINK or REGULATOR for the gennerator....  So when you connect a 6v generator to a 6v battery you will get 7.2 volts or so..... Connect that same generator to a 12 volt battery and it will be around 13 volts...
The BATTERY is more or less a REGULATOR of the voltage.... remember the old days when they said "dont pull the battery terminal off when truck is running"  ??... you can blow out the head lights or other equip when the generator voltage SPIKES..
You may not get a lot of CURRENT or AMP output... but you will get a lot of VOLTAGE.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 54 minutes ago at 10:37pm
If I’m understanding this correctly someone could run the old 6v cutout on a 12v battery without any issues?
I’ve got a 45 gas that had the 6v cutout until I put a 12v regulator on it that was apparently a dud, it don’t charge worth a crap anymore.
It did charge for a bit so I’m guessing something burned out inside.
I never knew a 8 volt battery existed for a car…
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 53 minutes ago at 12:38am
In most cases, an 8V Battery is a bandaid. You're much better  off purchasing a 6V Battery for your 6V system. Just make sure the Gennie is setup on the money and you won't have any problems. In the time the Tractor isn't used, keep a Battery tender on it to keep the Battery "active". You'll get a lot more longevity out of the Battery, and when you need the Tractor, the Battery is fully charged, ready to rock n' roll, and the Tractor fires right up. If you use the Tractor in the Winter months, make sure you install a lighter oil for the cold Winter months..   HTH
Steve@B&B
This page was generated in 0.085 seconds.
