Charging 8V battery |
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1570 |
Topic: Charging 8V batteryPosted: 26 Jan 2026 at 4:05pm |
My friend dropped off an 8V battery out of a 1946 Ford that someone had installed. What is best way to try to charge this? I have several chargers but nothing 8V. I think the battery is no good. I will check voltage of it first and go from there. Thx.
Edited by Ed (Ont) - 26 Jan 2026 at 9:37pm |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5136 |
Posted: 26 Jan 2026 at 4:13pm |
You should be able to charge it with a 12-volt charger on the lowest setting, without hurting anything.
Several battery chargers had a single setting for "12-volt low - 6-volt fast charge". Edited by WF owner - 26 Jan 2026 at 4:15pm |
Joined: 11 Sep 2009 Location: illinois Points: 89840 |
Posted: 26 Jan 2026 at 4:19pm |
and if you have a volt meter, connect it across the terminals and monitor as the battery is being charged with the 12v charger..
Ed (Ont)
Posted: 26 Jan 2026 at 5:01pm |
Thanks guys!
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7597 |
Posted: 8 hours 12 minutes ago at 4:21pm |
I was just talking to my starter and alternator repair shop a few days ago and got on the subject of 8 volt batteries in 6 volt systems. In short, they DON'T work! The maximum output of a 6 volt generator is only 7.2 volts, so the 8 volt battery will never get fully charged, instead it keeps draining. A 6 volt battery with a 6 volt electrical system that actually WORKS is a far better choice - a good working generator and very thick battery cables.
Les Kerf
Posted: 6 hours 7 minutes ago at 6:26pm |
Actually, they work well enough that Allis-Chalmers offered it as standard equipment on the W226 Power Units. ![]() It is a simple matter to adjust the Third-Brush type generators to properly charge an 8 Volt battery, my late Father-in-law ran his WD this way for decades with no ill effects.
Posted: 5 hours 60 minutes ago at 6:33pm |
a 6 volt generator NOT CONNECTED TO A BATTERY, will put out about 14 volts... A 12 v generator NOT CONNECTED TO A BATTERY will put out 28 volts... I have measured that several times....... The BATTERY is the SINK or REGULATOR for the gennerator.... So when you connect a 6v generator to a 6v battery you will get 7.2 volts or so..... Connect that same generator to a 12 volt battery and it will be around 13 volts...
The BATTERY is more or less a REGULATOR of the voltage.... remember the old days when they said "dont pull the battery terminal off when truck is running" ??... you can blow out the head lights or other equip when the generator voltage SPIKES.. You may not get a lot of CURRENT or AMP output... but you will get a lot of VOLTAGE.
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1255 |
Posted: 1 hour 56 minutes ago at 10:37pm |
If I’m understanding this correctly someone could run the old 6v cutout on a 12v battery without any issues?
I’ve got a 45 gas that had the 6v cutout until I put a 12v regulator on it that was apparently a dud, it don’t charge worth a crap anymore. It did charge for a bit so I’m guessing something burned out inside. I never knew a 8 volt battery existed for a car… |
