Cast iron on a C
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: Cast iron on a C
    Posted: 02 Sep 2019 at 7:35pm
Brought home a C tractor. It has Cast iron valve cover, oil pan, and the oil pans on the finals are cast. Serial number is 75861. Why the cast?
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2019 at 9:27pm
War time model C. Steel was rationed for domestic use during the war. Manufacturers used cast instead where they could.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2019 at 10:53pm
1948 trany swaped on to a war time C allis was out of war time parts long before 1948.so my guess is a later trany swaped in. You could try to match the engine serial number but thats kinda a crapshoot. The engine serial numbets were spread across B&C power units and implement engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 6:54am
Engine is a 1945. The war time WC had a pressed steel rear end because casts were not  easy to come by during war time. No casting for WC and more castings for the C?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 3:47pm
I’ve wondered that myself, why the WC got steel and the B/C got extra castings.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 3:55pm
I will venture to say most all war time Bs and Cs on steel also had cast iron valve covers and oil pans. Final drive oil pans too.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 4:36pm
So I'm thinking that the WC, with a frame to carry the engine, front suspension transmission, the rear end could be replaced with stamped steel and still work while  Bs and Cs had to still had their cast steel because there is no load-bearing frame.  However, they could replace non-load bearing covers with cast iron, not cast steel, which was not as important to the war.
Shot in the dark.
Edited by HoughMade - 03 Sep 2019 at 4:36pm
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 4:54pm
Perhaps Bill Long may know?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 5:30pm
I could be wrong here, but I think I read, somewhere, that the "cast" covers were actually pot metal...  be gentle, if you are gonna prove me wrong, LOL!Wink
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 8:33pm
The main reason was stamping capacity, all machinery was under the authority of the War Production Board, and Stamping equipment was running at capacity for the war effort. It wasn't as much about the material as it was about the equipment required to produce the parts. Allis farmed out many stampings and procurement was probably difficult at best, castings could be produced in house with little equipment required.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 8:38pm
still makes you wonder why the WC went to a stamped rear end... it was already a cast unit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 9:18pm
Rearends were made by Timken axle, during the war, Timken was making lots of truck, half track and tank drive train components. I have no idea who built the fabricated rear ends. War time production was a case of finding someone with capacity who could do whatever. Examples are rifles produced by Underwood typewriter company, Saginaw Steering Gear, IBM, and Rock-Ola. All capacity and equipment was controlled by the Government with reports filed on what every man and machine was doing monthly, with the Government dictating price and priority of all work. I believe that the Government suspended tractor production from everyone but Allis Chalmers, just like they stopped passenger car production.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 10:41am
The cast items on your tractor indicate it is  wartime C.
I checked the serial number and found that the highest C number is 1949 68281
I would check again 42 - 45 serial numbers 12389 - 30695
Remember by the gear shift on the transmission.
Sounds like you have some rather rare parts.
You know I still say the C was the best looking tractor Allis Chalmers made
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 6:47pm
Thanks Bill for prompting me to look at the serial number again. The tractor is outside now and I went with glasses on. Looks to me that the number is 35861. Swinford's book has it as a 1945, which agrees with the engine number. So would this be a wartime?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 7:38pm
I would say so. If the engine number and transmission serial number match, I think that'd be a neat one to restore as a "war time tractor"...those cast iron pieces, heavier cast rear wheel centers, steel wheels, tall air intake, wide fenders, etc. that were particular to the war tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 9:54pm
I wonder if the Cs had the wide fenders, being that the wheels were farther from the fenders than the Bs.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2019 at 4:37am
I have two war time, steel rear wheel B's. Both were "barn finds". Both had the tall breather, wide fenders and thicker "four bump" wheel centers, but neither had cast final drive covers, oil pans or valve covers.
The one I am restoring is a 42. According to the guy on charge of the auction sale where I bought it, it had been sitting in a shed since the late 50's or early 60's and had never done much actual work.
The other is a parts tractor (fenders and air intake have been sold already, but I still have the 4 bump centers), If I remember correctly,  it's also a 42 .
Edited by WF owner - 05 Sep 2019 at 4:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2019 at 3:09pm
Yes it is a Wartime C. Remember WWII ended in 1945. There had to be a lot of Wartime equipment left. Believe me we at that time we were glad to get ANYTHING to sell.
Good Luck!
Bill Long
