Carb question
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Topic: Carb question
    Posted: 17 Aug 2012 at 6:33pm
Trying to get Dad's "B" ready for the show tomorrow. Had a lot of rust and crap in the tank. Cleaned it as best I could without removing it from the tractor. Added a stand pipe in the tank and an inline filter. Cleaned the carb best I could.
It isnt getting gas. I think the needl;e is sticking. If I take the carb apart and lossen the needle the motor gets one and only one gulp of gas and quits. Its a Marvel shebler 154. Ive been told by agco and others you cant buy a kit for it. I have the gaskets but whats the best way to get the needle and seat? I'd like one that is ALL brass. The ethanol seems to raise heck with the rubber. Thanks  Brian S
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2012 at 7:20pm
Tony  (one of the vendors on this site) has kits for the M-S 154 Carb.
I don't think it is a rare item.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2012 at 10:33pm
Hello Brian    Start at the drain under the carb,  shuold have a good stream for at least 10 seconds,  if not undo the fuel line at the carb, same here, if not  remove the sediment bowl from the tank again, let run for awhile into a coffee can.     If it runs good under the carb the main metering jet is possibly pluged.   A can of brake clean or carb cleaner should clean the jet and passages an air hose is help ful, There doesn't seem to be a need for needle and seat or rebuilding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2012 at 5:39am
Hey.. Thanks for all the help. I got it running fri. nite and it made it to the show, Dad hasnt been doing well lately and I wanted to get the "B" , his 616 and HIM to the show.
Thank you Brian G for coming to the show and making sure I got it running. It was a great visit we had and thanks for helping me Tow start that fellas IH 560. (we used the 616). I have pics.
Also had fun chatting with John Clark another great AC guy. Glad he was able to use the "U" radiator thats been hanging around.
This page was generated in 0.119 seconds.
