carb kit for a gas 2200 on an h 4 allsis crawler
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Topic: carb kit for a gas 2200 on an h 4 allsis crawler
    Posted: 06 Oct 2021 at 11:59am
so my Allis H- 4 started running bad. it has the 2200 gas motor. I pulled the carb off and took it all apart to clean. it says zenith on the carb and I haven't found any numbers. so I need a kit for it. I've found some om eBay with what looks to be the right bowl gasket but none say for an Allis h4. anyone know the right number i need to look for or where you might have bought one before. any info is appreciated. thanks for reading.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 9:01am
Pinball:  have you tried reaching out to The Carburetor Shop LLC in Missouri?
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 9:35am
motor.................... carb........... carb # ......................... kit
G-2200Z 26713044 (4020322-2)CK945
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 9:41am
Adding to Steve(Ill) information - AC H-4 parts book shows Gasoline Carburetor Repair kit for H-4 Gas Crawler as Part Number 4056411.  Excerpted from page 193 Form 1012402 Reprinted 11-1975 replaces form TP-104.
Also - see Zenith information here:
 http://www.zenithfuelsystems.com/downdraft_228.htm  Might work if no kit available.
HTH's - Orangeman
Edited by orangeman - 07 Oct 2021 at 10:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 4:08pm
Thanks for the info.
