carb cleaner |
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Topic: carb cleanerPosted: 16 Jul 2018 at 8:08pm |
what do you guys use for soaking carb parts when rebuilding? I have been using an over the counter carb cleaner (don't remember off hand, the brand) but I just am not happy with it. Im not convinced it's getting the crud out of the teeny tiny ports
I am still confident of this;
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 16 Jul 2018 at 10:00pm |
Berryman Chem-dip. Not what it used to be with EPA regs but still does the job just takes a little longer soak.
shameless dude
Posted: 16 Jul 2018 at 11:47pm |
would brake clean work?
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Posted: 17 Jul 2018 at 6:59am |
I got this from YouTube and it does work great. Use Lemon juice and boil the carb parts in it for bout 1 hour. It leaves a grayish film on parts that comes off easily with water. I went to Dollar Tree and got two quart bottles for $2.00,,,,like I said,,it works great,,,,,,,
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8479 |
Posted: 17 Jul 2018 at 2:55pm |
X2! I use that method, and the Berryman method. Both work. The lemon juice method is cheaper, though. I used the Berryman method on a WD45 carburetor. Let it soak overnight, and the next morning the whole thing was stripped clean.
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 17 Jul 2018 at 5:10pm |
(MEK) methyl ethyl ketone, acetone, and gas is a pretty potent mix. Should just about dissolve anything in the carb. Keep sealed, very high VOC's (volatile organic compounds) involved. Use in well ventilated area very flammable. Wear gloves, avoid breathing. I use to do environmental crap for a printing company where I worked after I hurt my back.
Edited by chaskaduo - 17 Jul 2018 at 5:12pm |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4077 |
Posted: 17 Jul 2018 at 11:37pm |
i like to put them in a metal can of plain e10 gasoline for a day rinse and blow then to the ultra sonic cleaner for an hour at 150*
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 20 Jul 2018 at 12:27pm |
I'm gonna have to try that lemon juice one!!
Regular carb cleaner is getting pretty expensive. |
