Can anyone identify this Model G part? |
Scott(GA) ![]() Silver Level ![]() Joined: 13 Sep 2009 Location: PeachtreeCityGA Points: 407 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Sep 2011 at 8:57am |
This item is being auctioned on eBay? I'm wondering what it is?
Scott
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Just what he says. A spacer to make the tractor an inch longer. Gives an inch more foot room and room from seat to steering wheel and for a hair longer cultivator. There was a thread on this forum about building long spacers for the G for longer cultivators last spring. I've not found it today. They were looking at welded up spacers 4 to 8 inches long. Two plates and a tube welded together.
Gerald J. |
Gerald,
I don't think the main function of this part is to add length. To me, the round machined area with the concentric hole would seem to receive - and hold in place - something like a ball joint.
Why the machined area if the only goal is to add an inch of length?
Best regards,
Scott
To clear something like a center bolt at that junction in the G structure. There were several pictures of longer spacers in the previous thread that I didn't find by searching. That search was slowed by a thunderstorm taking down my power.
Gerald J. |
Look at: http://www.allischalmers.com/new/forum/forum_posts.asp?TID=31404&KW=cultivator+extension&title=fabrication-friday there's a fifth bolt in the middle of that junction, (see the third picture) probably for hanging some implement so the spacer plate has to clear the head of that bolt.
That fifth bolt shows poorly in some of the G pictures over on YT. Most times its in shadow though. Gerald J. |
Gerald,
I found one other discussion (might be more) from February of this year.
It was titled "Allis G extension".
Your point about "clear something like a center bolt" is well taken. I'm familiar with that bolt - it holds the foot rest onto the frame. I'm not trying to be argumentative but...
Why machine a smooth hemispherical (spelling?) hole when just casting the part with a hole would do the same task?
I'm not a machinist but that looks like a lot of work (ie. money) just to provide clearance for a bolt.
Best regards,
Scott
Hmmmm...
Looking at the picture again, I'm trying to decide if the "hemispherical" look is a trick of lighting or not. I don't think so but without being able to hold the piece and feel in the hole it is hard to know for sure.
Lighting, rust & dirt could make a concentric set of 2 holes (eliminates the more expensive machining) look curved.
Best regards,
Scott
Edited by Scott(GA) - 03 Sep 2011 at 1:38pm |
The back piece on the big tube up from the drive end is a casting, so it could easily be curved and the front piece is fairly thin steel plate that could curve to the curve of the back piece and some pictures of those I referenced tend to make it look curved, though that could be just the outline curving.
Cast vs machining is a constant decision in making a part. It depends a lot on the equipment available and the time period. Often a casting takes more machining than cutting such a curved piece from flat plate and pushing the possible spherical shape into it with a big press. Today a plasma cutter driven by computer or in recent decades a cutting torch with a pattern cutting attachment to follow a pattern with a magnetic drive shaft could cut steel plate without much manual labor or when set right by much need for sl*g cleanup. I'd think a cast piece would not be accurate enough to keep the front wheels in the same tracks as the rear wheels at that sensitive point in the G tractor frame, so machining it would need, where the plate was more uniform in thickness. One thing I've noticed about AC tractors is that there is some tendency to use steel stampings in places where other makers used castings and forgings. As if AC engineers could save money bashing stock sheet with a press compared to working sold rods into forgings with ball ends. Like hand throttles and throttle segments on WD. So if the extension plate was factory, stamping (and for plate that size punching four of the holes is quick) seems logical. In the smaller shop it all depends on the equipment available. I know a couple shops with torch and plasma cutters and my little Clausing mill with a suitable jig can do the holes. I did 8 bigger plates to change the rear tires and rims on my green tractor a few years ago for spraying. Just posted that picture on the thread about narrow pulling tires a while ago. Gerald J. |
RichinWis ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Deforest Wis Points: 691 |
the bolt hole in the middle is for the head of the bolt that holds the footrest on.
oldironguy ![]() Silver Level ![]() Joined: 01 Oct 2010 Location: Shoreview, Minn Points: 373 |
Given that no one on this site seems to recognize this piece, I'm guessing it is not an AC factory product. While I may have overlooked it, I don't see it in any of my G parts books. If it is shop made, it's another example of the skill and creativeness of the North American farmer.
All that said, I'm not bidding on it.
Dick
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10781 |
I'm with Scott on the hole. If it is indeed a spacer, there is no need for a counterbore, a thru hole is cheaper and all that is needed.Foot rest bolt nut is welded to plate that is welded to front tube. HTH Tracy Martin
When drilling a large hole with a standard 118 degree point drill bit the worst time is when the bit breaks through where it digs in and grabs the work piece. If the work piece isn't truly anchored to the table, the piece spins at the drilling speed. So if there's enough clearance without going all the way through its plenty good reason to NOT make the hole all the way through. No broken drill, press, or operator. So that's what? A 5/8 or 3/4 bolt so the bolt head would be about a half inch high and drilling deeper than 1/2 inch just wastes time and electricity turning steel to air space that isn't needed. The stock was reported as being 7/8" thick. Plenty room to stop.
The taper of the drill point will produce an appearance of not flat as it should. The taper of the drill bit point though helps hold the drill centered on the pilot hole which a flat tipped drill will not unless its a special with a built in pilot. And a worn drill often has round corners at the edges of the hole. You grumble about how a 118 degree drill point wanders try grinding a drill flat with cutting edges and then drilling. Even in wood it will leap all over moving a drill diameter per revolution. I've tried that once. Only drilling with a milling machine is rigid enough to make it work, like a plunge cutting end mill. A drill press isn't stiff enough. A hand held drill motor is hazardous with the flat tipped drill. Gerald J. |
Dick,
It's possible [perhaps not probable] that one or more members of this forum recognize this part but are waiting until after the auction ends to identify it.
Best regards,
Scott
