Can a 6080 run a White planter blower?
977.3Ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 977.3Ford Quote  Post ReplyReply Direct Link To This Post Topic: Can a 6080 run a White planter blower?
    Posted: 19 Feb 2026 at 10:56am
Looking at putting together a 9 row 20" white bean planter. Would a 6080 have enough hydraulics to run the blower and raise/lower the planter, or would i have to use a PTO pump?
Jimmy
1982 8050 Powershift
1982 6080
1992 R52 Gleaner
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:25am
I would think they would but you will probably need to add a 'power-beyond' valve. You'll need someone smarter than me to help with that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:10am
I've never been a fan of using the tractors hydraulic system to power something like that for hours on end, especially if I could avoid it. The service life of an engine or hydraulic pump is "X" amount of hours at a certain HP/pressure output. So, pick your poison. Use the tractors hydraulic system, and figure on maybe rebuilding it someday down the road, OR use a PTO pump, utilizing it doing what it was designed for. In this case, you have a choice. Sometimes you don't.  To answer the original question, your 6080 is probably 12 GPM at the remotes at full throttle, so 6 GPM at 1200 RPM. What does the planter require ??
Edited by DrAllis - Yesterday at 8:12am
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:12am
Yes, but No, don't try.  You need a PTO pump.  I run a blower on our 185 for replants etc by taking off the the traction booster outlet on the pump and plumbing it into the blower direct with a 2500 psi safety dump. The motor return goes to sump. Works fine just have to keep the rpm up above 1600.  So it doesn't take a lot of gpm. The 6080 is an open center system that has 2 sections - one for the power steering with a pressure relief dumping to sump = you don't want to pressure the return from the steering motor. The other goes to the remotes. You can not Tee into this and unless you devise a flow control , well it gets complicated. A power beyond is used to power the 3 pt and attaching here will kill the blower when the lift/remote is actuated. Get the PTO pump. In the past I ordered a generic pump with way too much gpm and it heated the system even using a L2 gleaner for reservoir and cooler so spend the $ and get the OEM pump with reservoir and remember it floats on the pto shaft - do not bolt it to the drawbar.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 42 minutes ago at 6:28am
I run a Pit Express with one of the 6080’s it does it but not fast.   IIRC you have a bigger tractor search out a 8/15 Kinze it will be mechanical driven and a much  better planter.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 40 minutes ago at 7:30am
Agree with pto pump choice.
I’m currently configuring a 540 pto JD planter hydraulic pump to run a Kinze 3000 vac & Vset meters. Anyway I see lots of White Air planters using this exact same pump. From your comment/question your White planter’s hydraulics are plumbed for tractor & so maybe no pto pump?? Which is it?
Don’t believe Deere mfg it, but maybe mfg’d by Command? Its housing is what I would refer to as a “half-moon” shape. It is an aluminum housing reservoir/pump combination. From searching the internet & talking to owners/operatorsof such pto pumps it appears these pumps produce 5-6gpm volume. Believe the JD(7200s) & Kinze(3000s) use ~ 3gpm for their motors. I don’t know about White planter blowers volume.
It’s aluminum housing dissipates some fluid heat buildup, but an in-line radiator(12”x12”?) with no fan is all that is needed to help cool hydraulic fluid. Hydraulic fluid recommendation is 10w(AW32). Most if not all White planter’s blower housings usually incorporate a cooling radiator near their intake to draw air over hyd fluid radiator~ good design.
If this JD pto pump is of no avail, think the older IH Cyclone planters pto pumps will suffice? Or if no other options, a older Chevy c10/c20, GM, Ford, Dodge power steering pump can also make do…?
Edited by AC7060IL - 2 hours 32 minutes ago at 7:38am
