Cam bearing tool |
WC7610
Joined: 11 Sep 2009 Location: Sioux City, IA Points: 764 |
Topic: Cam bearing toolPosted: 12 Sep 2015 at 4:29pm |
Hi,
What are you using to remove cam bearings in a B engine? special tool? make your own?
Thanks
Most Bad Government has grown out of Too Much Government- Thomas Jefferson |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54739 |
Posted: 12 Sep 2015 at 5:34pm |
Search Youtube, here's 1:
[TUBE]http://youtu.be/NPlCr7PZCUc[/TUBE] Edited by DiyDave - 12 Sep 2015 at 5:35pm |
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 12 Sep 2015 at 6:27pm |
You can take the block to the machine shop, engine re-builder or maybe the local parts store will rent one like this one, it expands tight in the bearing and keeps the bearing from warping as it's pressed in place. Please look at the pics before you replace your bearing.
B26240
Posted: 12 Sep 2015 at 7:12pm |
What ever you use don't forget to line up all the oil holes.
WC7610
Posted: 12 Sep 2015 at 8:09pm |
Yeah, thats why I'm asking. Got the block back from being sent away to a machine shop, they replaced the cam bearing- didn't ask them to do that but before I started putting the Cam back, I though I'd better check the alignment for the holes. One was 1/3 and the other two not even close
Thanks
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 12 Sep 2015 at 9:06pm |
I have the same kit Don has shown above, and it works great. Yeah it's a bit pricey, but you don't screw up bearings if you use it properly.
Still in use:
MACK
Posted: 12 Sep 2015 at 9:38pm |
Use a long drill bit and redrill. MACK
bradley6874
Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Posted: 13 Sep 2015 at 8:54am |
Take it back to th machine shop they screwed it up let them fix it if they miss it up again its there nickel not yours
Don(MO)
Posted: 13 Sep 2015 at 1:48pm |
O-no that's not good. You might do a test fit of the camshaft in the block if the cam fits OK, then I do just what Mack said, drill the holes through the cam bearings, clean the bearings from the drilling and retest the camshaft fit, if it's OK put her togather and don't worry about the cam bearing holes that are off. I'm just thinking out-loud. |
DiyDave
Posted: 13 Sep 2015 at 5:51pm |
It they are already in, I'd try drilling, if you can do it through the oil gallery/block. Be sure to de-burr/countersink the inside surface of the bearing...
MACK
Posted: 13 Sep 2015 at 8:32pm |
If you send it back, they may drive them back out and reinstall them. Then they will fit block too loose and turn with camshaft. MACK
WC7610
Posted: 14 Sep 2015 at 7:53am |
Thanks for the info!!!
Thanks
AllisRocks
Joined: 18 Aug 2016 Location: Wautoma WI Points: 11 |
Posted: 24 May 2017 at 4:52pm |
I read this post too late and destroyed my first set of Cam bushings on my Allis Chalmers D14. (149 engine) I made this tool afterwards and it works great... about $5 to make from tractor supply. I lightly tapped them in. Maybe could press them in also using this tool.. The washers fit perfectly in the bushings.
AllisRocks
Posted: 24 May 2017 at 4:54pm |
![]() This is a picture of it on the used bushing. |
Gary in da UP
Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
Posted: 24 May 2017 at 8:14pm |
What Mack said X2
