Calling fellow big D17 drivers... |
AllisD17AndyOk ![]() Silver Level ![]() ![]() Joined: 06 Apr 2020 Location: Colbert, OK Points: 51 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Jul 2020 at 10:50am |
Hey guys, brought a D17 series 3 few weeks ago, getting it to be like I want. My current issue is the seat. I'm 220 lbs. and sitting in the seat not moving and bounce up and down, feels good, even driving...but when mowing pasture and hit a rough patch, when it bounces, it bounces hard, bottoming out (hard!). It had already been adjusted to heaviest driver, so what can I do to improve the ride? Will replacing springs or shock (or both) help, even if feels good not moving? Can't replace seat with aftermarket as one of previous owners welded the seat bracket to rear end when adding center link for 3 point conversion. Thanks for any advice Andy
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
Replace shock with stock Allis shock. I am 6.2, 260. That fixed mine.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22091 |
The spring carries your weight. The shock keeps you from bouncing like a jack-in-the-box. The spring adjustment needs to be all the way forward and tighten the bolt/wing nut TIGHT so it cannot slip. The spring may have lost some of it's strength after 60 yrs of use.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5156 |
Take the shock to a GOOD auto parts place and have them match it to a gas charged shock. The pressurized gas will add to the weight rating.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54368 |
In addition tho what was said above, I believe there was a rubber baby buggy bumper type thingy, that stuck up from below, that softened the bottoming, IIRR
Nope. Not on a D-17.
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6088 |
Mine bottoms out, too... I'm only 215. I try to avoid the rough spots, and keep my weight on my feet, because it does jar the hell out'a my back. I guess I'm getting old!
DanD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: WI Points: 856 |
I always drive with the seat in the bigger taller position to have enough legroom too. It also changes the geometry of the seat suspension making it able to hold a lot more weight.
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
the top of the shock can be adjusted. Further back for more weight
Bill Deppe/AC Salvag ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 974 |
Important the rubber shock bushings and bronze bushings are not worn bad
