Cab interior kits for 8000 series
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Cab interior kits for 8000 series
    Posted: 09 Jan 2019 at 1:43pm
Cab kit you would recommend for Allis Chalmers 8000 series tractor.
Manufacture  and supplier .
thanks
Fred
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 6:19pm
Hy capacity has good kits as well as Fehr cab interiors. Not sure who’s a dealer in Canada for them. I’m a dealer for both.
Edited by Carl(NWWI) - 09 Jan 2019 at 6:20pm
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 8:23pm
I have got them from Carroll Imp in LuVerne, Iowa. Hy cap brand. When reinstalling, dry fit first. Start with the fenders and work up. Drill out the rivets in the right hand irons and the headliner comes out some what easy.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 8:24pm
I put a Fehr cab kit in our 6080 in the fall.  Very good quality looks identical to the original.  Highly recommend.  Google "Fehr cab kit" and you can order right on their website.  Best to pick it up when you are in the USA.  It comes in a huge box!
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 7:42am
Fred I,ve installed Hi-cap kits in both of our 8010,s, the first was 5 years ago and it wasn't too bad but not great, did the 2nd one 2 years ago - it was not nice. Long story short if I ever do another one I will use a different brand! Dave
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 7:54am
Thanks Dave
Has anyone installed Fehr cab kit and was the kit tailor fit.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 8:43am
I used Fehr kits in my shop and sold them always fit good  always fit dry first on any kit
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 12:10pm
I put Fehr headliners in the 8010 and 8050 last winter. They fit really good. Only advice I can give is cut the holes for speakers and radio out at a 45 degree angle that way if it’s off a little bit you don’t see a gap. Made that mistake the first time. I ended up making plates to go behind the speakers to cover the hole.
Also. The head liners go in and out the back window. You will be pissed off if you try to go in through the door. Don’t ask how I know
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 1:13pm
Used Fehr in 8070...good stuff
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 7:31pm
I have redone three 8000 series tractors with Fehr cab kits and they look great but don't hold up, the vinyl comes loose form the foam especially on the head liners. My tractors do not set outside except maybe during planting season and rarely at that. The vinyl started coming lose after about four years. I plan to contact them about this but haven't done so. Maybe tomorrow!
rieg
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 3:57pm
Fehr is a great company to get kits from. Ive installed 2 into both of my 8070's. The first one being 8 years ago and still looks new and holding up great. In fact, i just bought 2 gleaner cab kits from them. Just waiting to make time to get them installed.
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 5:27pm
I know the correct police will crucify me, but I removed all the foam/vynl, then sanded, taped and spray painted the interior. The headliner, I brushed on a textured matching paint. It took a little time but I've done it on both 8050's and have no regrets. I think it looks as good as new. And yes, the head liner has to come out the back window. The foam/vynl just isn't durable enough, especially when you start mounting monitors, GPS systems, fold boxes and so on. The noise level is no different than our 8070 factory cab.
Just my 2 cents.
Leon B Mo
