CA Rim Eccentrics
bigun1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigun1 Quote  Post ReplyReply Direct Link To This Post Topic: CA Rim Eccentrics
    Posted: 29 Sep 2015 at 1:38pm
I have a new rim for my CA, but I need to loosen the eccentrics. The rim that I just acquired has one of the 1/2" squares twisted off already. I don't want to break any more. I have not gotten rough with anything yet. I heard that someone had a "tool" they had made for loosening these. Can I get some good advice beyond PB Blaster, heat, bigger hammer. Thanks
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2015 at 1:49pm
I took an extention, flipped backwards with a socket on the impact and worked them back and forth, all four came right off...
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2015 at 3:53pm
I have taken them off the center dish, dropped them in a muratic acid (available at Wallyworld and swimming pool places) solution for 3-4 days, and this helps a lot to loosen them up! Neutralize with baking soda, prime and paint or at least oil them, because they will develop a film of rust overnite!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2015 at 5:30pm
Best way is still to remove them, one at a time, and get them moving, by soaking in penetrating oil, placing in vise, and tapping forward and back, on the cam.  Once you see it move a little forward or back, then try turning it with a wrench.  Takes about an hour per clamp, good work, on a winter day...
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2015 at 7:07pm
  put them in a fire for 15 min.  take them out- they will be loose -wire brush and never seeze and ready to go--have done many
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2015 at 7:37pm
I removed the retaining ring and put on the side burner of the grill for 15 min or so, then pressed them apart..........
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2015 at 8:07pm
yes, if you go to all the trouble to take them apart, run them against a wire wheel, and never seize them, before assembly....
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2015 at 8:32pm
Remove the bolts on all of the clamps and beat the center out of the rim. Not as hard as it sounds. If you remove the clips and hammer on the pins, after lots of PB Blaster, they will come loose. I have done many sets this way. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2015 at 3:04am
I just got done with a video that will show you the complete process. Just click on the link below. It is about 30 mins long but covers everything from dismounting the wheel and remounting the wheel. The complete process.
Wheel Eccentric Repair
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigun1 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2015 at 9:48am
Hey, thanks to all. I appreciate the responses. This tractor belonged to my Dad, who purchased just before I was born. This  1 rim was rotted out and I want to replace it without tearing something up. Again, THANKS to all.
drapert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drapert Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 3:48pm
I watched the you tube video with great interest, as it showed how to get the wheel back on--but at the moment, our AC doesn't have power (carb is being rebuilt)--HOW to get this durn wheel on without power???
Need help before my husband drops the tractor on his head....would be really helpful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigun1 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 3:54pm
Once I had the rim re-assembled I put the tire and rim back on the tractor. While it was still up on the blocks, I was able to spin the wheel and tire to the position I wanted before I thightened the eccentrics and fully tightened the bolts in the center dish. It was pretty easy actually.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 5:46pm
That's why I does them one at a time.  If the tire is loaded, getting from the horizontal to vertical is a real pain.  Do 'em one at a time, and you can take the bottom one out, and re-assemble, then roll the wheel , take the next one out, etc, etc, till you're done...
Post Options Post Options   Thanks (0) Thanks(0)   Quote drapert Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 5:52pm
Well, he had to take it all apart (left the hub on the tractor) to put on a new tube--there was some repair to do on the rim--welding etc. He even went out and got longer bolts in hopes of getting it together, but that doesn't seem to be working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 11:18pm
I seem to be missing something. I don't understand why you need tractor power to mount the wheel. Can you please explain in more detail?
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote drapert Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2015 at 8:19am
According to the video, you have to run the tractor to turn the wheel so that the extension bits that screw on the wheel hub--to hold the tire on. Right now, the rim is in two pieces--the part that goes on the tractor (still on the tractor) and the part that holds the tire on--
The whole assy is VERTICAL--and hubby doesn't want to take off the hub to make it horizontal, and he's having trouble getting the ext pieces on in place so he can get the bolts to go through--
He fiddled with it for hours yesterday. Help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2015 at 10:31am
Put the tractor in neutral and try to turn the wheel by hand to line up. If that don't work then take the wheel off. Is there a reason why he wants to leave the wheel on?
Thanks & God Bless
Dennis
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2015 at 11:05am
He needs to take the center section off the tractor and lay it on the floor like in the video but it may take a few more hours of frustration to make it clear to him. Pinch
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote drapert Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2015 at 6:50pm
Well, he's going to give up until spring. Maybe at that time, I can convince him that it will be WAY EASIER to work on when it's horizontal, and there is no tipping of the tire and having to work around the weight of the tire on the rim--Sadly. he spent so much time on it unsuccessfully, that he gave up and rolled it back into the garage to wait until spring. Just too much frustration at the moment.
Thanks all for the tips, and I'll save this convo and video to view again next yearl
