CA Restoration - Hyd/Tran oil leak
Dale (Stonelick) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Topic: CA Restoration - Hyd/Tran oil leak
    Posted: 03 May 2020 at 1:07pm
After driving a partially restored CA several times, it has developed a hydraulic/transmission oil leak from the left final drive housing (drips from the inspection/drain hole under the left brake drum).  The Final Drive illustration in the manual shows 2 Oil Seals on the shaft that enters the differential housing that might be the cause of the leak.  Would appreciate any advise on the following questions.
1. Are these 2 oil seals the probable cause of the leak, or could it be something else?
2. What is safest way to jack up and secure the left rear axle and differential?  The tractor has a WFE.
3. After removing the left rear wheel, the final drive assembly looks like it will still be very heavy.  Will supporting it with chain and front end loader work okay as I remove the four bolts?  Or is there a better/safer way?
4. After removing the four bolts, will the final drive assembly pull free off the Shaft or are there some snap rings and/or keys that have to be removed first?
5. To get to the 2 leaking oil seals, it looks like a snap ring holds the shaft and oil seals onto the differential.  Is this correct?
Thanks for any information/suggestions you might have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 8:12pm
Most likely the inner seal is the worst problem. The outer seal requires a lot of dis-assembly of the final drive, where as to replace the inner one, you'll only need to remove the final drive assembly.  You can jack up and block under the transmission and remove the final drive assembly at those 4 bolts and then slide it out. A service manual for reference would be a big help to you.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2020 at 9:02am
Agree with Paul B. Leaking inner pinion seal. Easy to damage a new seal when installing the axle and the damage does not show up until you are done. Block front tires, remove interfering sheet metal (floor pan, fender, fender bracket, brake linkage, etc). Jack up and support with GOOD blocking under tranny and remove tire. I use an engine hoist (cherry picker) to remove the final; however if you have the space available a loader could work to support the final. Final is held in by the 4 bolts and there are no retainer clips involved. Recommend obtaining genuine AGCO seals; the after market ones from the auto store are more flimsy (get a pair just in case you ruin one installing it). Make sure the final is level when reinstalling it and go easy with it; the new seal can be damaged by the pinion shaft when re-installing the final.
C in Concord View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C in Concord Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2020 at 12:47pm
Hi Dale,
I agree with Greg and Paul on the inner seal, and I'll add that the shim(s) sandwiched by the diff's bearing retainer can be another source.  Manual says to alternate shims and gaskets, but I've only ever seen metal shims.  I've heard excessive shimming could result in leaks.
Disassembly is 4-bolts for the housing (slides out), 4-bolts for the retainer (mine were extremely rusty).  Retainer slides out.  Seal is pressed into the retainer.
Like Greg, I used a cherry picker on my 'C' with a strap.  Image below shows were to loop it so it balances.  Rest of chassis was supported by a splitting stand I built and some tall, wide based jack stands.
Oh... and mice friggin' love the hollow areas of the final drive...
Not a bad job really.
Best of luck!
Ben
Edited by C in Concord - 04 May 2020 at 1:29pm
Leave things better than you found them.
1941 Model C (restored 2020)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2020 at 4:48pm
Thanks for the responses.  I plan to order the seal(s) in advance and want to make sure I order the correct one(s).  The parts illustration (see below) shows 3 oil seals, which I labeled (A), (B) and (C).  I think it needs A and/or B, but I'm not sure.  It seems that A and B oil seals are drawn as different dimensions.
Steiner's parts catalog shows only one oil seal for the "outer upper final drive shaft seal" which is 1.375" ID x 2.720" OD on page 60.  So do I only need this for the one labeled (B) and don't replace the inside oil seal labeled (A)?
Appreciate any information you can provide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2020 at 5:59pm
closeup.........
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2020 at 6:03pm
I think the "B" seal might go down a foot INSIDE the final drive case and seal the final drive lube from getting OUT into the brake shoe area..... I would guess that "A" is the seal you need for the  outside of the differential case to keep the TRANS OIL INSIDE... I wonder WHY this seal is not shown with the DIFFERENTIAL case / bearings and shims ... on the other page ?
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2020 at 6:17pm
Dale, I've got two manuals here: Operating Instructions & Repair Parts Manual which came with the tractor, and a Jensales reprint of the AC Parts Manual. Your parts diagram appears to be the one in the Op Inst & Repair Parts Manual. Both show the oil seals you labeled as A and B. The original part #'s are 800351 for A and 206449 for B. [These would now be 70800351 and 70206449, I believe.] Both manuals imply that both A and B are used to form the inner seal and are held in place with a snap ring. Paul, Greg and C are all referring to "the inner seal" so maybe what used to be a two-part seal is now a single seal. Or maybe there's another, better explanation! I'm guessing that this is just adding to the confusion, so perhaps a call to Bill in the service area at Sandy Lake Implements might clear things up if one of the other posters doesn't jump back in to do so.
The advice to carefully reinstall the final drive is right on. Probably easier with a cherry picker than using a FEL. And a great excuse to buy one if you don't have one already!!
Good luck with your project. Please let us know how you make out.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2020 at 6:20pm
A cross sectional view looks something like this.. The A seal on the far right keeps the trans oil (ORANGE) from getting into the brake area that is DRY.... the B seal on the far LEFT keeps the differential gear lube  (GREEN) from getting into the brake area that is DRY... The GREEN gear lube is "SLING" around by the big bull gear.. There is only a couple inches of lube in the bottom... The ORANGE trans lube is up on the shaft / seal and easier to leak thru seal "A".
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2020 at 6:29pm
here is the differential case... this should be the seal you are looking for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2020 at 6:40pm
That cross-sectional diagram sure clarifies things, Steve. I've only replaced the inner oil seals once and that was years ago...memory is fuzzy as it's old!! Thanks for clearing up my post!
Dave
Edited by Dave(inMA) - 05 May 2020 at 6:41pm
WC, CA, D14, WD45
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2020 at 6:55pm
Yeah, mice love them finals fir' sure!  And the stink will make ya puke!  Yuk!  Make sure ya wear gloves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C in Concord Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2020 at 7:52pm
Dale,
Looks like Steve(IL) and Dave have you covered. If you are having a hard time finding the inner seals (seal 'A'), DJS has them, link below. I used them and they fit well. A bit $$$ though. If you order by size, National (or similar) might be able to save you some. 1.187" ID, 2.004" OD, 0.250" wide.
https://stores.djstractorparts.com/axle-seal-ab-1628d/
Ben
Edited by C in Concord - 05 May 2020 at 7:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2020 at 8:20pm
Don't wast your time with Stieners, Call Sandy Lake.  Brenda or Sara will have all of the parts you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 2:49pm
Brenda at Sandy Lake mailed me the $14 oil seal they suggested was the problem (the "A" seal on my diagram).  This was consistent with everyone's comments and the seal's dimensions are the same as noted by C in Concord.  Brenda sent me a better parts diagram that clarified the difference between A and B seals, similar to what Steve(ill) posted.
Thanks for all the help.  I'll look into getting a engine hoist cherry picker or maybe a manual chain hoist before starting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 5:29pm
Thumbs Up Thumbs Up Thumbs Up  Let us know how you come out.
Want to post the diagram that Brenda sent you?  Or email or text it to me?
VErY informative thread.  THANKS for starting it.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 6:18pm
Here's a short video that may help!
CA seal replacement
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 8:14pm
Ted:
Below is the parts illustration link that Brenda emailed me.  If it's not viewable, send me your email address by private message and I'll forward it to you (or anyone else who wants it).  I was not able to paste the pdf as a picture.
