CA rear rims - 10" or 12"
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Topic: CA rear rims - 10" or 12"
    Posted: 24 May 2010 at 9:11am
My rear rims were about shot when I bought my 1952 CA over 20 years ago, but the right side finally gave out yesterday.  I need to buy two new rims.  My present tires have printed on the side "12.4x24 on 11" rim  11-24".  I've seen 10" and 12" wide rims for sale.  Mine appear to be just under 12" wide when measured from the far outside.  I've heard some say they should be measure from the inside where the bead sets.  If so, they would be about 11" (which seems odd).
Any suggestions?  I'll probably go with 12" unless I hear major objections.  The only thing this tractor does is have a Woods L-306 belly mower on it.
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 12:04pm
Measured from the inside of the bead  seat they should be 10 "  If you need a good set of used I still have one set for sale .  in Michigan
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 12:15pm
Hi Brian!  The CA rims are 10" on the inside shoulder to shoulder. On the tire size charts, they say you need to have the rim narrower than the tire to have good holding force so as to not rotate or slip the tire on the rim.  I have 2 sets of tires & rims for my CA. A newer set of 11.2 X 24 on 10" rims and a worn set of 13.6 X 24 on 12" rims for doing some EXTRA playing with!!!
DeWayne
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 1:11pm
Thanks, DeWayne!  Do you use the bigger ones for the sub-soiler races?  LOL
Brian F(IL)
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 5:32pm
Hey Dewayne, I'd like to see your ca with those 13's on it. Got any pics?
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 9:06pm
Hi Brian & CA Ron
I am going to try to do some pulling this year in the 3500 & 4000 lb class.
I have the tires mounted on the rims and extra wheel centers. They are not on the CA yet. Maybe in a week I will have them on the tractor & take some photos to see how they work out! Brian, bring your Sub soiler up to the AC Jamboree this year!
DeWayne
scooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scooter Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2010 at 8:24am
DO YOU STILL HAVE THE RIMS FOR A CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2010 at 8:32am
Dad put 13-24's on the CA right after he sank into plowed ground trying to disc with it way back in the 50's. They stayed on it till I had a blow out in 98. Filled with fluid they made plowing a breeze. I think I might have a picture on my old PC. The 13-24 would be the same as a 14.9 today.
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2010 at 5:14pm
scooter I do still have the rims if intrested
Gleaner Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gleaner Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2019 at 5:16pm
I am restoring a 1952 CA. Does anyone have 10x24 spin out 4 rail rims for sale or know a good source for me to get them?
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2019 at 6:18pm
I have one. Lot of rust inside but no holes that I can see - cheap!
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2019 at 6:42pm
I ended up buying 2 new ones b/ c any of them I bought used my ag co tire place couldn't change the old ones without bending them all up and ruining them in the process of putting new rubber one the old used rims...
I had them shipped directly to ag tire place...
