CA questions
Larry in OK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Topic: CA questions
    Posted: 30 Jan 2010 at 7:17pm
Found the engine number on my '51 CA  it is R 14620 G. Is this correct for a '51 CA or has the engine been changed out?
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 9:36pm
I suspect it has been changed out. R prefix is a 60H gasoline power unit engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 9:42pm
Thanks Ken.
Any idea where I can find information about this engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 10:27pm
It has the standard 3 3/8 bore if it hasn't been rebuilt with a overbore kit. The governor is probably a standard rpm unit. The CR prefix power units turned up 1900 rpm. It should be just fine as a tractor engine. It is the same basic engine used on later Bs, All Cs and CAs. Often these power unit engines have had lower running hours than tractor engines the same age. If they were on a combine they sat idle most of the year. Makes sense I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 10:40pm
I've known this tractor since the late '70s but my relatives that know the history have either passed on or have Alzheimer's. So far as I know it has been in use with this engine since then.
I did learn that some time in the early '70s the tractor caught fire and fell over when it burned. My uncle rebuilt it after that and had been using it until he got sick in 2008. Just a wild guess but that might be when the engine was swapped out.
