CA question
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: CA question
    Posted: 03 Sep 2015 at 8:01pm
How much noise is normal for a CA drive train, (transmission,  rear end, final drives)?
Mine makes a whinning  growling noise when in 4 gear driving on the road.  I am beginning a tear down for painting and thought if I need to get in the gears now would be the time.
Thanks,  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2015 at 8:12pm
I would suggest you try to get a feel for bearings and end play in things before you pull it all apart. Timken taper bearings will run loose way longer than they will tight, but gear noise increases with excess slop.That being said, spur gears in the finals can and will howl some no matter how good the gear is, more noticeable running in 4th gear.
 A good cleaning and snugging up any loose points with new gear lube may quiet things down some.
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2015 at 8:18pm
I went through mine completely and like Mr. Tucker says they always have the growel in forth and reverse, I haven't drove an AC yet that didn't.
AC's 75' 7040, 64' D-17S4, 55'WD-45, 54' WD-45, 53' WD-45, 53' WD, 52' CA, 36' WC. IH 656. Deere's 38' A, and 47' A
MrHDC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrHDC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2015 at 8:38pm
My '52 CA has always made noise in 4th. Not really a growl - more like a "whishing" noise. I'm sure "whishing" is a technical term. My memory only goes back to about '62 when I was 5. That's about the time I started driving it.
Hervey
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2015 at 8:00am
Mine is pretty quiet in all gears but it will pop out of third going down hills.
rpropst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpropst Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2015 at 8:05pm
Tim If you want to drive my CA to see if it sounds the same as yours just give me a call and let me know when you would like to come.
Richard Propst 828-291-1757
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 6:48pm
Thanks Richard,  I'll give you a call,  maybe after the 13th..........Tim
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 7:56pm
My CA is pretty quiet. Both WD 45s are also pretty quiet. My C however has a lot of gear noise. Dads C And WD also had a lot of gear noise. The CA and WD 45 both used constant mesh transmition. The sliding gear transmition used in the C and WD were a lot noisier.
