CA Project Pics |
Page 123 6> |
Author | ||
dfwallis ![]() Orange Level ![]() Joined: 09 Mar 2023 Location: DFW Points: 803 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Aug 2025 at 12:04pm |
Believe me, there are plenty of dings, new and old :) And the paint job is substandard. I had great difficulty getting the water out of the compressor feed 400 feet away in the garage... and I'm not really sure how VS can call this paint "super premium".
1952 CA13092
Sponsored Links | ||
jvin248 ![]() Silver Level ![]() ![]() Joined: 17 Jan 2022 Location: Detroit Points: 449 |
That photo looks like a tractor fresh off the factory assembly line. . Edited by jvin248 - 05 Aug 2025 at 8:45pm |
My original plan was to use 5 x 2 or 5 x 3 rectangular tubing, but I was unable to get it locally (at least quickly). It's still an option for reinforcement.
Edit: I was surprised at how nice and square everything fit together. When I clamped the vertical risers to the cultivator bracket, they met almost perfectly flat and inline with the other side. The reinforced angle brackets mating the side rails to the top were preformed items I bought off the internet. I've used those on the side rails in places also, except those were slotted and these I had to drill. There was almost no distortion caused by tightening all those bolts at the top. Of course it all started with the guy that welded my bail together. I stressed to him how important it was to be perfectly square. Edited by dfwallis - 06 Aug 2025 at 3:45pm |
1952 CA13092
I don't really like what I've done, but there was just not a lot of good options. The supplemental bail mounts to the cultivator bracket position. This gives me pretty good vertical support on the axle (but of course requires the wheels spun out just a bit, which I don't mind because it's a tiny bit more stable). I left a vertical protrusion on purpose while I was deciding whether to add a canopy/ROPS. So the vertical frame supports for the canopy are attached to this vertical protrusion above the cultivator bracket. So as to not further limit how far in I could bring the tires, I mounted the supports on the inside toward the fenders. This then limited the thickness that I had intended to use to gain ROPS strength. The thickness I wanted worked on one side but not the other, perhaps bent fenders (didn't bother to see where it was off). For now, I use clamps (half inch plates with 4 half inch bolts) with a single 3/4 through pin with an R clip. It is rock solid. You can pick the tractor up with it with zero deflection, zero rotation. I used 3/4 x 4 inch flats for ease of fitment. I could easily add some square tubing to the outside of each rail to improve the side to side bending resistance, again at the cost of limits on tire adjustment range. All because i didn't want to mod the platform. I guess I could have bought another platform and modified it like I did for the PTO guard, but then again, there's not many other good locations to bolt onto other than giant clamps around the axle (like the H and M use). Edit: Those rails are pretty darn heavy. I may not be able to lift them into place in a another few years :( ![]() ![]() Edited by dfwallis - 04 Aug 2025 at 8:42pm |
1952 CA13092
DSpears N IL ![]() Silver Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Rockford,Ill Points: 415 |
can you share some pictures of the canopy mounting to the outside of the fenders?
The uprights look to be good for the canopy to hold. Thanks Dewayne |
08/03/2025 Status:
1) After contacting the vendor of the GTC505 analyzer, I discovered that they have a firmware update that relates to misinterpreting mechanical distributor signals that don't quite transition to zero volts between firings (I assume trigger not resetting due to not seeing the required voltage transition). After installing the 211C update, the electrical misfires were completely eliminated. So I went back to assuming carburetor issues. I found a cheap knockoff zenith (advertised as a replacement, but I believe somebody made a copy/paste error as it was not the correct model to replace a TSX486). Anyway, the new carburetor completely eliminated the misfires at idle. I had cleaned and replaced about everything in the TSX486 (had it apart about 12 times), but something is still wrong, so I sent it out for a "professional" rebuild. I'll try it out next trip in late August (2025). As for the knockoff zenith, I had to bore the (stepped) main jet out from 0.0645/.0600 all the way to 0.0990 before the tractor would run above idle (the TSX486 is at 0.0990 #39 drill). Was severely gas starved at anything above idle. These zenith "universal" carburetors are horrible. They have small diameter mounting studs that allow the carburetor to be misaligned causing the throttle plate to get stuck rubbing against the flange hole (maybe the reason for extra gaskets, but there were no instructions). Also, you have to cut off and grind the throttle rod, else it won't mount and even grinding it all the way to the lock nut, it still rubs the block when it rotates. I don't recommend anybody use these if there's any way around it. Find a proper TSX and stick with it. Also, if you DO install the zenith, you MUST modify it (on a CA), which then makes it non-returnable. Edit: I've decided that I could probably just bore the zenith mounting stud holes out to the correct size and use the TSX mounting bolts and nuts. That should eliminate the alignment issues. Was slightly scary when the tractor revved up uncontrollably a few times :( 2) Spent some time on the hydraulic pump bracket. I completed the design of the bracket for the front (dual mount front or at the belt pulley). Unfortunately, the 5 inch engine pulley I got won't work because the 1 inch spline is too large to go through the crank hole. 13/16 is about the largest shaft that will go through without mod, which I don't want to do. I need to research another pulley with a 3/4 spline. The one I bought with the 1 inch spline is the one recommended for a CA, but it is not compatible as-is. This is critical for knowing how far out to mount the pump and what shaft adaptors I need to accommodate. This isn't a high priority project though. 3) The majority of the time was spent on the canopy install. I designed a fairly robust mount, but unfortunately falls a little short of ROPS strength (but I don't plan to test it). There are options for bracing/strengthening, but I'm not sure I will proceed. Dad thinks I should make it foldable like many ROPS, but I don't think I want to do that. The canopy isn't too bad for $250 (you get what you pay for). But it is just a little bit flimsy and flaps in the wind and road bumps. You know that's going to rapidly crack without much use at all. I could probably add some strategic reinforcements (but should I really have to???). I did find a deficiency with my drawbar supplemental bail design and made a minor mod to block rotational (front to back) movement. It was designed to hold the drawbar up, but those giant lever arms for the canopy apply quite a bit of rotational force. The bail is attached with clamps and could slide with enough force. Of course it wouldn't go very far, but zero movement is better. The canopy is easily removable. I also made the bracket it mounts to removable because it was too tall to fit through the barn door. I did raise the barn door to a consistent 92 inches all the way across (was sagging in the middle), but that only gives me 1/2 inch of clearance with the canopy mounting bracket, so I'll probably still remove it since it's really easy to remove. ![]() ![]() ![]() 4) The AGCO guy was able to straighten my cultivator lift arms (logging accident or a wreck down a ravine, not sure which). He didn't charge anything which was nice. I had primed most parts on the June trip and just gave a coat of orange (other than the lift arms). ![]() ![]() 5) I spent one day doing some electrical work in the barn. A little tired of tripping over tangled extension cords. 6) Worked on the hydraulic tank mounts. What I designed needs a minor mod to add a hangover lip to prevent it from slipping off sideways. I decided to add some rubber mounting pads to the tank. Too much metal to metal scuffing. I'll probably glue them to the tank. 7) I investigated whether mods are needed to prevent the PTO shaft from angling too much with the finish mower. As is, the lower lift arm travel is limited to 2 inches below the angle it sits at on flat ground. The limit is how far in the hydraulic cylinders will go. If it needs to be limited further, I could add some non-scuffing collars around the cylinder rods, maybe. I was unable to find a protractor or anything to actually measure an angle, so I ordered one for next trip. I'll consider what happens when the rear end of the mower tilts upward also. The angle is probably not ideal, partly due to the add-on "overrun" clutch, partly due to the "flexible/floating" 3-point top link attachment which may be allowing too much flexibility. At least on one occasion, the PTO shaft pressed against the top link bracket on the mower and gouged the plastic protector. 8) Added a manifold 1/8 port to allow a vacuum reading. After determining that my cheap vacuum meter was not correctly calibrated, I manually "calibrated" it and got good readings of ~22 inches hg. This was confirmed later with a higher quality meter.
Edited by dfwallis - 04 Aug 2025 at 11:54am |
1952 CA13092
I worked on the wedge pins to clean them up and paint them. Wire brushed, sanded, wire brushed, and soaked (washed in dish soap a few times too). I left a few specs of original paint on for character :). I didn't spend much time on the chain since it's a spare. I just coated with primer for safekeeping. If anybody might need one, I might part with it. I believe it is in pretty good shape with 12 links:
![]() I only soaked them for about 4 hours. I'm not sure if the WD40 version is the same as Evaporust or not. Seems similar in performance. ![]() Painted the wedges and the SAE-B hydraulic pump mount. I noticed a few missed spots and took it back out to touch them up after the pic. Was too dark in the garage when I painted. The mount is aluminum. The paint will probably interfere with pump mounting. I'll fix that later if needed. ![]() My workshop in TX is typically slightly more toasty than the one in IN. After I turned on some fans to bring in outside air it went "down"...to 106 :( As long as a fan is blowing directly on me, not too bad. ![]() |
1952 CA13092
DSpears N IL, yes I believe I saw those pics in my research. I like it. If I can't identify a ROPS suitable attachment that still allows me to rapidly reconfigure to pin-hitch implements, I may do something like that. Your pics may be where I got the idea from :) I like the hard shell canopy better than the canvas, but I haven't finally decided anything yet.
1952 CA13092
![]() ![]() It is Not Rollover approved, but worked well for my lawn maintenance applications!
Some new documentation to study. I'm pretty sure grandpa had the cultivator manual, but I can't find it. I found some relevant loader manuals. In particular, the 100A seemed to have been targeted at the CA, D10, and D12. What's the chance of me ever finding one of those??? :(
1952 CA13092
My brother thinks he remembers seeing one of these "recently", but I searched high and low to no avail. So I found these online for a pretty penny. I have both the original chains, they were still attached to the bracket. I could probably take a metal detector and scour the 40 acres and find them both... I don't really like those cheap knockoffs they're selling, but I could probably have machined them to look a little closer to the originals. ![]() Edited by dfwallis - 05 Jun 2025 at 7:01pm |
1952 CA13092
Thanks Chris and Cheryl :) I was happy with the most recent trip. Still a few things planned: Left side final drive oil pan, clean and apply gas tank sealer compound (did the right side already because it was leaking). Get it running better (B and B working on the distributor, install correct venturi in carburetor)...? Explore ROPS and Canopy (I've used (thick) flat steel so far and I know C-channel might be better/stronger but flats are easier for me to fit). I think 3/4" flats will be acceptably strong as compared to a typical thin walled C channel or square tubing, when corner braced. I could easily go thicker if needed. Of course, adding a ROPS will complicate removing the drawbar with 3-point in use, since it will attach to the secondary bail I created for the 3-point mods. That's not very desirable since I want it to be easily reconfigurable. Explore secondary hydraulic pump mounting options. I'm inclined to design the bracket to support either mounting via rear belt pulley or on the front via the installed cultivator bracket (i.e. both places as needed), designed for easy removal to reconfigure for cultivator use. I've been looking at the front engine pulley (adaptors, spline rods) that's commonly sold. It does not support the hand crank, but I think I can mod it to supply both a spline and a hand crank fitting. That is, if there is room for the hand crank fitting which is doubtful (from memory), but I haven't measured it. I might try cutting the hand crank notch out of the spline fitting if there's enough metal to work with. Possibly silly, but I want to keep the hand crank capability. Edit: I intentionally chose a CW pump to interface with the belt pulley better in my selected mounting location. I would need a CCW pump to mount on the front. I'll probably go ahead and make the dual bracket, but I'd have to buy another pump (SAE B mount) to use it on the front.
Edited by dfwallis - 05 Jun 2025 at 6:49pm |
1952 CA13092
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8502 |
Very detailed work on getting your CA preforming again. I like it! Should be a great tractor for years to come too! Thanks for sharing your journey. (Might get me going on my old CA project too?)
Regards, Chris and Cheryl
I'm not sure how often it might be useful, but I don't like the idea of going down the road with the implement raised in the "hold" position with the PTO off (to stop blades from turning, etc.). I've not detected any droop so far, but for longer distances between fields, I might just disconnect the PTO shaft and leave the pump on. So, I made a little PTO shaft hanger with a lock mechanism (probably unnecessary). It should hang on the PTO shield extension through a single hole (to be drilled). I had intended to add a little flare of the top hanging end straight outward as a sort of locking mechanism for the top attachment, but I should have added that bend first because it no longer fit in the bender tool or vise conveniently. I doubt it would bounce out anyway though. If I decide not to add the bend later, I may need to shorten the top hook just a bit to avoid the PTO shaft if needed. Surprisingly, my cheap tubing bender bent this solid rod easily. But it didn't quite have enough throw length, and I had to finish it in the vise. I looked at some rebar benders that look useful for these types of brackets. I typically do these in a vise. I have an Eastman bender that does a good job, but sometimes the bend radius is not sharp enough and sometimes the bend is too complex (or part too small) to fit the part in. Edit: I compromised and bent the tip of the top end straight back (90deg) instead of out. The hole in the PTO shield bracket will need to be slightly larger to accommodate inserting the upper end and rounding the 90 degree bend. I only scuffed the paint a little. ![]() Edited by dfwallis - 29 May 2025 at 2:58pm |
1952 CA13092
:) Thanks, Dan. I just couldn't bear to see it wasting away. Probably not the smartest thing I've ever done, but it was fun.
1952 CA13092
CA13414 ![]() Silver Level ![]() Joined: 25 Feb 2024 Location: Nebraska Points: 358 |
I really like how you added the extension off the PTO shield. I think I will do that with a flashing LED light and a slow reflector. |
Spectacular and awesome job! What a transformation!!!!
Dan |
Toward the end of the trip I began cleaning up and priming the cultivator and side weight brackets. You can see where the right side of the cultivator lift arm is slightly bent in. I left this with the former AGCO dealer to see if he can straighten it a bit. It looks to be bent exactly straight inward, little to no twisting. I didn't have anything substantial enough to clamp it to. ![]() ![]() |
1952 CA13092
First use after 30+ years was to mow a small field with a finish mower at the highest cut setting. It did fairly well. Two videos are posted at: https://www.youtube.com/@OrangeAcres-h2k One shows the tractor state as of March of 2023. The other shows the tractor in use mowing this field. I didn't start recording until after the field was mowed and I was going back over chopping the "wind rows" and missed sprigs. This was 3 feet tall in spots. ![]() Edited by dfwallis - 28 May 2025 at 11:24am |
1952 CA13092
In order to keep the PTO shaft from hitting the implement top link bracket, I modified the rear to top link braces to bring the top link bracket fully vertical and inline above the lower lift arm attachments. This significantly improved the PTO shaft clearance by several inches (mostly problematic at the lowest lift position). The old Zephyr 510 450RPM 1/2 inch drill nearly broke my arm drilling those large holes. I remember it almost broke my arm in the 60s when I used it too. I was surprised it's still functional :). ![]() |
1952 CA13092
One of the last things done was to apply all the decals (not all technically in the right positions). I don't think the "CA" decal was designed quite right. It had a rectangular box around it which caused the decal to wrap around the front of the cowling. I guess I could have placed it lower, but the directions indicated it should go in front of the lower hood bolt. The hood and gas tank were severely damaged in various logging accidents. I spent more time than I had trying to improve them, but there were too many other mechanical issues I had to get to so I cut my losses. I may revisit it one day. ![]() ![]() Edited by dfwallis - 29 May 2025 at 11:40am |
1952 CA13092
The original bail was initially just moved furthest back in the hangar on the bottom side of the draw bar. In order to get it further out of the way of the 3-point lift arms, it needed to go further back about 3 inches. This necessitated a spacer (shown below). The original bail is used to provide part of the horizontal stability of the add-on bail. It still only requires removal of 3 pins to completely remove the drawbar (e.g. to connect the plow). However, it is a bit heavier, and advisable to remove the 3-point arms to lower the weight a bit. ![]() The bracket needed to move the bail forward required a 3 inch spacer which I luckily had an exact 1 inch thick x 3 inch remnant available (got a few more coats of orange after this pic). ![]() |
1952 CA13092
I installed the overrunning clutch (fixed with a roll pin, April trip). I then created a bracket for the PTO shield to extend it out to prevent the rockshaft mounted top link bracket from going down too far and contacting the PTO shaft (might not happen in operation, but could if something broke or a pin came out, or ...). This provided a mounting option for the safety emblem and rear spot. I also installed the platform and fixed some hydraulic leaks and adjusted the linkage. I fit checked the seat cover but didn't leave it on because my sitting on the floor working on the hydraulics and bail got my clothes pretty dirty. I may only install it for special occasions to hide the severely rusted original seat. ![]() Edited by dfwallis - 29 May 2025 at 11:35am |
1952 CA13092
I added an extension on the PTO shield to keep the rockshaft mounted top link bracket from going down too far and contacting the PTO shaft (if something went wrong). This allowed me a convenient mounting point for the safety emblem (it was previously on the old original PTO shield, which I have saved unmodified). I also added a spotlight on the top. This is one of the original headlights. Both were pretty mangled, but I made one good one out of the two and a repair kit for the bulb socket. It has an LED bulb, but I'm not sure if it's bright enough. There are LED bulbs in the headlights too, but I couldn't locate the same non-polarized bulbs I used. The headlight bulbs are 2X brighter. The bracket is just a tad too close to the seat, but I don't think it will be a problem. I can always move it back if it is. ![]() I created an adjustable bracket for the spotlight. I can point it pretty much anywhere I might need it. It isn't quite convenient because you do need a wrench to hold the bolt while tightening the wing nut. I may find or create a lock for the bolt heads to make it easier. I ordered some 2-tab washers that may work if the tabs are long enough. Bend one tab up and one tab down. ![]() Edited by dfwallis - 28 May 2025 at 1:08pm |
1952 CA13092
Tires balanced. It took 15oz for the left front tire and 20oz for the right front tire. This dramatically improved/eliminated the wild oscillations in 4th gear. I was disappointed in the tire shops I called pooh poohing balancing these tires. Both rims show to be bent but they are very large gradual bends all but invisible unless you use a straight edge to compare with. The right side tire has a heavy weld in two spots where the rim was destroyed by a tire ballast leak in the 60s, but surprisingly, that was not where the imbalance was. I did have to grind the weld down a little in one spot to get the wheel weights (not the clip on balance weights) to center. ![]() ![]() Edited by dfwallis - 28 May 2025 at 11:11am |
1952 CA13092
Mounting of the step on the left side in front of the clutch. This is a better location than the designed placement at the cultivator mount on the torque tube. I never really had any trouble getting on/off, but this does make it a bit easier. ![]() |
1952 CA13092
5/28/2025 Status: Quite a bit of progress was made on this recent trip: 1) Replaced the venturi in the TSX486. The one received was not a good match but I machined to match (length, new one was too long for the top of the carb to tighten into position). The major hole diameter of the venturi was also smaller. Was not happy about that, I was very clear to the vendor to ensure it was correct for a TSX-486 (can't tell from the online pic). The documentation implied it was correct, but it obviously was not a good match (I've since ordered the correct venturi). Anyway, the engine does run better and noticeably leaner (did not overheat with a good workout). The spark plugs are no longer rapidly coating with carbon. So, I'm sure that was part of the problem (although still not fixed correctly). It still misses sporadically. 2) I Completed the bracket for mounting the step on the left side rail in front of the clutch pedal and mounted the step. 3) Balanced the front tires. On the road, the wheels and steering wheel were WILDLY oscillating. Several of the tire places I called didn't want anything to do with it (thinking it couldn't possibly matter going that slow, but it DOES in 4th), so I bought a harbor freight bubble balance and some I7 weights and did it myself. The result was a dramatic improvement. No more wild oscillation. The tires were each off around a pound. It took 20 oz to balance one and 15 oz to balance the other. Depending on whether they were in or out of sync, the amount of oscillation could be dramatically different as well. 4) Applied all of the decals. 5) Made brackets for the safety emblem and added a spotlight above it on the rear of the tractor. Wired the spotlight. First switch position is headlights/taillights, second position adds the rear spotlight. I purchased separate magnetic flashers for occasional use on multiple tractors. 6) Modified the finish mower to lower the rear mounting points of the rails that attach the rear of the mower to the top link bracket. As designed, they were so long that they pushed the top link bracket supports too far forward which caused the PTO shaft to hit the supports in certain lift positions. I pulled the top link bracket on the finish mower back to be fully vertical and inline with the lower lift attachments. This mod requirement was partly due to the geometry of the 3 point mods to the tractor (OR clutch extends the PTO shaft, top link bracket on the rock shaft causes the top link to be further rearward than normal which makes for a very short top link connection...and PTO shaft). 7) Verified that the generator/regulator is in fact generating...whenever it takes a notion. I assume it just doesn't see the battery as being low enough voltage to turn on most of the time. A simple LED current draw plus ignition doesn't seem to be enough. 8) Although they won't immediately be mounted, I cleaned up the side weight and cultivator brackets and began painting (ran out of orange but they are primed and ready). The cultivator lower arms (1-3/8 inch diameter rods) is bent on one side. I left that with the former AGCO guy to straighten if he can. I didn't have anything substantial enough to clamp it to. It only needs about 1 inch of movement straight outward. It seems to still be in alignment otherwise. It looks like someone ran into it exactly from the side, head on into the end of the rod. 9) After first use mowing a small field with a finish mower, it was clear that I had to make a minor mod to the 3-point hitch bail attachment. The lift arms needed to go down further. I previously made some flex attachments to allow them to go lower, but that caused a clearance problem when lifting. Because horizontal stability uses the legacy drawbar bail, it was necessary for me to move the old bail forward a few inches to let the 3-point arms drop further without hitting the bail. I knew that was likely coming and wasn't too worried about it. I made a new bracket to attach the legacy bail and the 3-point lift arms can now go all the way to the ground (and beyond). 10) I uploaded a new video (Youtube https://www.youtube.com/@OrangeAcres-h2k) showing the original state of the tractor as of March of 2023. A second video of first use of the tractor mowing a small field with a finish mower was also added. 11) I shipped the distributor to B and B for rebuild. I'm not convinced this is the cause of the misfires, but the end play is around 2X what AI says is the spec (.014 to .017). I wasn't able to confirm the spec and saw .010 and even smaller elsewhere. 12) I added an extension on the PTO shield to keep the rockshaft mounted top link bracket from going down too far and contacting the PTO shaft (if something went wrong). This allowed me a convenient mounting point for the safety emblem (it was previously on the old original PTO shield, which I have saved unmodified). 13) I also installed the platform and fixed some hydraulic leaks and adjusted the linkage. Edited by dfwallis - 28 May 2025 at 12:00pm |
1952 CA13092
I'm guessing that the generator may have stopped charging for the same reason as the tail light stopped working, lack of ground. Seems less likely, but all the brackets were painted and I also used flat washers in places because the lock washers I had were not quite large enough for the slide section to clamp down properly. The last thing I remember doing was tightening the belt that had come loose, I may have changed the washers at that time and didn't notice it stopped charging until later. Its always something...
1952 CA13092
:) Thanks, I wish I had more time to work on it. Traveling to my parents a week here and a week there makes for slow going. Part of the reason I get frustrated when I'm wasting too much time on one thing (like the hydraulic pump). But I am inching closer to having it functional and useful again.
1952 CA13092
DFW
Great pictures of your continued work on your nice CA! Might get me moving a little on ours! Regards, Chris and Cheryl
Page 123 6> |
