CA Power Steering
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Power Steering
    Posted: 15 hours 28 minutes ago at 5:29pm
1952 CA13092
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 22 minutes ago at 5:35pm
Trying to make it into something it was never intended to be!!
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 58 minutes ago at 6:59pm
I have a CA wide front, not that hard to steer unless you spread it out for two row plowing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 23 minutes ago at 7:34pm
My narrow front is slightly hard to steer with the front wheel weights on.  Don't really need them for the 3pt mower I think (580lbs).
1952 CA13092
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 41 minutes ago at 6:16am
I have 2 WFE CA's, going to pass on this mod.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 37 minutes ago at 7:20am
A good quality ball bearing spinner on the steering wheel would be a good start. Grease the spindles with the front end jacked up. 30 lbs of air in the front tires would also be beneficial. Turn the front tires around narrow and it will steer easier. OOOpps I guess you can't with the new fangled steering arm welded to the left spindle arm !!! seesh......
Cernunnos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cernunnos Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 8 minutes ago at 7:49am
Even though that is not needed by me on my CA's, I do admire inventors and others that think outside the box, whether it is a great success or not.  Their ability to see a problem and come up with a solution is admirable. Thank you for posting the video.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 8 minutes ago at 7:49am
I guess I have to give him a few points for trying but my goodness.....
