CA magneto |
CBMike
Topic: CA magnetoPosted: 19 Jul 2020 at 9:45am |
The little grounding post broke off of my magneto. I'm wondering if I need to try and EZ out the broken piece or if I can use one of the screws holding the cover on to ground it. As of right now, my tractor is not running due to needing a new starter so I can't just try it
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 19 Jul 2020 at 12:38pm |
That would be a bolt that goes all the way thru inside an insulted insert.
CBMike
Posted: 19 Jul 2020 at 1:05pm |
Dick L,
If I'm understanding your comment, I'm going to have to disassemble the magneto to get to the bolt from the inside and replace it. Along with making sure the insulating insert is good and in place. Do I have this correct?
Dick L
Posted: 19 Jul 2020 at 2:55pm |
Yes sir!
Joined: 11 Sep 2009 Location: illinois Points: 90834 |
Posted: 19 Jul 2020 at 4:08pm |
CBMike
Posted: 19 Jul 2020 at 4:17pm |
Thank you all for the help. It is much appreciated. I just got done watching a video on the rebuild. The young gal made it look easy. Now to find some parts
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5191 |
Posted: 19 Jul 2020 at 4:57pm |
Many magneto parts from the link in the video have very good prices.
You may also want to try www.brillman.com
Edited by WF owner - 19 Jul 2020 at 4:58pm |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 19 Jul 2020 at 8:59pm |
Boy, I'm telling you that Creston ought to get ahold of that little gal. He would never have to rebuild anything again. She can do it all. What chou think Creston?
CBMike
Posted: 20 Jul 2020 at 5:03pm |
So I am going to remove my magneto from the tractor, hopefully tomorrow. After noting plug wires,should I remove the cap first and note the position of the rotor and/or look at anything else to help when putting it back on?
Posted: 20 Jul 2020 at 5:43pm |
yes.. taking the cap off is normally OK depending on what type mag you have... but the GEAR timing has to be right. If you move anything, it can change.. Need to look at the PROCEDURE for setting the GEARS right... also on reinstall on the tractor to set timing.
Posted: 20 Jul 2020 at 5:45pm |
read this BEFORE you pull the MAG so you know what your looking for...
CBMike
Posted: 20 Jul 2020 at 6:17pm |
You are all awesome. Thank you for the information.
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2400 |
Posted: 21 Jul 2020 at 5:58am |
Some tips that may help: Take pictures as you go. Mark gears so you can put them back and have them mesh as found. Don't turn the engine while you have the mag off. Bonus: you can use the pictures to post on here!
WC, CA, D14, WD45
WF owner
Posted: 21 Jul 2020 at 7:03am |
I put a dot of paint on the beveled or marked (metal gear) tooth. It makes it much easier to see now and if you ever have it apart again.
Grant
Posted: 22 Jul 2020 at 9:18am |
OLD CROAK MAGNETO has a large amount of info and advice on their web site. They have worked over a couple of mags for me and I was amazed at how helpful they were with advice and the price was reasonable. They are in Washington state. Grant.
CBMike
Posted: 22 Jul 2020 at 1:57pm |
So, I ended up saying the heck with rebuilding this myself. I, maybe or maybe not could have accomplished the job without screwing it up or struggling with the 2 notoriously troublesome set screws. So I contacted Rudy Calin over in Minnesota. Great guy. He had a rebuilt in stock. After 7 hours travel, I'm happy to report that I have a virtually brand new magneto in and my tractor instantly fires up and runs like a .... new AC!! Thanks everyone for your time and advice.
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6126 |
Posted: 22 Jul 2020 at 10:17pm |
Mike, That procedure rarely ever fails. It can be a little pricey, and there's transportation costs and time investment, but with it usually comes the opportunity to meet some great people, and stop at a small town diner for cheese curds!
