CA hydraulics
Kforeal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kforeal Quote  Post ReplyReply Direct Link To This Post Topic: CA hydraulics
    Posted: 27 Feb 2012 at 6:27am
Did the CA come with one or two hydraulic rams for the rear? Mine has one but I'm seeing pics with two.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 6:51am
 They came with two rams, one on each side.
Thanks & God Bless
Dennis
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 9:14am
You have to have two rams when you use, for example, the cultivator.  One ram lifts the rear, and the other lifts the front.  Then, you adjust the pump so that the front lifts and lowers first as you operate the pump control.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 3:24pm
Yeep two cylinders came standard. Perhaps somewhere along the line your CA had a woods mower under it. The mower needs only 1 cylinder to raise/lower it and the other cylinder may have been removed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kforeal Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 5:51pm
Yes Greg that's exactly it. Im going to have to locate another ram as I don't plan on using the mower so much. I'd like to get the 3 point set up. Light duty. Thanks fellas
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kforeal Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 7:14pm
Anyone have pics of how the two rams are connected and plumbed?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 7:47pm
the junction block is under the platform just to the left of the lower shock mount. You cant see it with the platform on. the two ram hoses come off the sides and the remote hookup comes up through the hole in the platform. It will still lift a three point with only one ram installed. with both rams installed it will lift way more than the front end will hold down. there is a good drawing in the parts manual. go to agcoparts and look under heritage line.
This page was generated in 0.049 seconds.
