CA hydraulics with #3 sickle bar mower
Orangeisgreat190 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangeisgreat190 Quote  Post ReplyReply Direct Link To This Post Topic: CA hydraulics with #3 sickle bar mower
    Posted: 20 Jul 2021 at 5:42am
We have a CA with rear mounted #3 sickle bar mower.  The mower has the tail wheel and lifts with a cylinder from remote.  Drawbar is not snap coupler.  Hydraulic arms fold down with cylinders pinned to them.  Then drawbar is pinned into the hydraulic arms.  When lifting the cutter bar with remote, you can see the tractors hydraulic cylinders actuate and put pressure on drawbar assembly just briefly.  Is this normal, or will it hurt anything?  I was looking it over to maybe adjust pump setting to where it would not do this.  I then saw where the remote valve is ran through the hydraulic hoses.  So, I assumed this is normal operation.  Does anyone have any thoughts or suggestions?  I just replaced the packing I’m both rear cylinders and do not want to damage the new seals.  Thanks guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 7:05am
It is working as normal.  For the #5 side mower there are 2 straps the also lock the lift arms, but the still move a slight bit as you have with the #3.
aliced141 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aliced141 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 5:08am
That is completely normal, pal. Don't worry
