CA Hand Clutch Restore - Final Update 4/23 |
Page <123 |
DennisA (IL)
Joined: 11 Sep 2009 Location: Ridott IL. Points: 2077 |
Posted: 07 Jan 2026 at 10:22am |
That is correct. What I’ve done in the past, with the clutch Assembled, is to totally collapse the springs and measure the gap in between the clutch disk and the pressure plates. Whatever that measurement is subtract 0.050” and that will be what you machine off.
Thanks & God Bless
Dennis |
rilenz
Posted: 22 hours 39 minutes ago at 5:12am |
I will be tackling the switch over in the spring. So defiantly will be watching your progress. Do have a another ? I rebuilt my hand clutch this last spring and sometimes I hear a squeal when disengaged. Might be an adjustment thing ?
Les Kerf
Posted: 21 hours 13 minutes ago at 6:38am |
I am just a rank beginner on the CA and learning as I go. We got this tractor last spring as a parts machine, Grandson got it running and putt-putted around with it last summer. It runs well but the main clutch is shot, the rear main leaks badly, and the brakes are toast. The hand clutch was totally soaked in gear oil and was so well-lubricated that it didn't squeal at all
Otherwise it functioned nicely and didn't slip, but we never really stressed it very much either. I only drove it a couple of times as Grandson had it commandeered most of the time ![]() |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8639 |
Posted: 17 hours 23 minutes ago at 10:28am |
Les,
Sounds like you need start at page one of my CA thread!:) your grandson will be very happy. Regards, Chris and Cheryl
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11209 |
Posted: 13 hours 51 minutes ago at 2:00pm |
I have had my hand clutch apart a couple of time and the second time all I had to do was retighten the bolts that hold it on, I didn't use locktite on them and now it's slipping again. I am not planing on trearing it down again.
Les Kerf
Posted: 8 hours 14 minutes ago at 7:37pm |
I have followed your CA thread with great interest; you do set the bar rather high for we mere mortals
Page <123 |
