CA Fuel Tank?
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: CA Fuel Tank?
    Posted: 06 Aug 2018 at 8:00am
I am needing a fuel tank for my CA. Will a tank from a B or C work? My tank is not beyond repair, but if I could find a good tank  that is the route I would go.  There was a CA tank on Ebay last week, but I missed out on it. None of the tractor salvage yards close to me has one either. Any suggestions? Thanks, Tim
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 8:05am
My CA tank has a dimple in the bottom on the right side to clear the starter switch. My C did not.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 10:18am
Dave is right. The B/C tanks will interchange, however, the starter mechanism is different. Have seen this were someone has also used the B/C starter rod/solenoid rocker when mounting the B/C tank on a CA.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 10:23am
My '51 B has the dimple under the tank for the starter switch mounted on top of the starter, so I bet later year Bs (that overlap with CA production) will interchange.
Edited by HoughMade - 06 Aug 2018 at 10:23am
1951 B
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 12:17pm
Is there anyway to take the tank apart to get the dents out of it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 12:29pm
That seems too complicated- cutting and welding.  Find someone with a stud gun (or rent one) and slide hammer, pull the dents out as much as you can, fill what remains with fiberglass reinforced filler, then skim with a little regular filler.
Heck, maybe a paintless dent guy can do it, but they are usually working on much thinner metal.
Edited by HoughMade - 06 Aug 2018 at 12:29pm
1951 B
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 2:10pm
I have a B/C tank for sale. PM me if interested.
Wayne180d View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne180d Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 8:03pm
Sent you a pm
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 9:23pm
The bottom is gone on mine, I started to work the dent out of it and the bottom has rusted almost through. The tractor had set for a big part of it's life with fuel in the tank. I bought the tractor from the original owners son and he had it running, but the tank was pretty crusty inside. I am using it to mow with, but have to stop and clean the sediment bowl frequently. I had taken the tank off and strapped it to my WD45 rear wheel with some chain in it, but the bottom was so thin it dented in when I strapped it tight. Live and learn I guess.
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 11:02pm
I know were a CA parts tractor is. I bought a few things off of it myself. I could check on the tank if you like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2018 at 8:18am
Yep sounds like you have done every thing you can for that tank. And it provided years of service too. So time for a good used tank. I haven't heard to many folks replacing half of the tank. There a lot of them out there sounds like a couple folks have them in this thread. Good luck and post some pictures. This may get me started on my WD45 tanks setting waiting for me to clean up.
 Always thought I should have a narrow front CA in the family too.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2018 at 9:55am
Have you tried Austin Salvage they are just South of Butler Mo. (660)679-4080.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2018 at 6:26pm
Late model Bs are the same tank.
Can't fix stupid
