CA erratic spark |
Page <123 |
Author | ||||
dfwallis ![]() Orange Level ![]() Joined: 09 Mar 2023 Location: DFW Points: 732 |
Per the user manual it is the coil ht. I'll see if it has a low voltage option...I might need the accessory kit for that. I think i got the missed fields all mowed. I may have some more time tomorrow. I usually spend the last day of the trip putting things back in their place but not as much to do this time. It also has a spark burn time test.
1952 CA13092
Sponsored Links | ||||
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1168 |
Ahhh... generally when I think of 'dwell' it is in reference to the amount of time (actually rotational degrees) that the points are closed; in which case if there was a double dwell period it would mean that the points didn't open that time around. I would be greatly curious to see whether that anomaly occurred at the exact moment when a blip in the vacuum signal happened.
You are most welcome!
Additional info Compression 1 - 4 130, 129, 132, 129
1952 CA13092
When idling very slow it sounds almost like the key was switched off momentarily, but the voltage to the coil or signal to/from the points never shows any hint of a dropout on a voltmeter. Wish I had an oscope to look closer. Oh boy, a new toy...hard to get my tek 536 on the plane.
Edited by dfwallis - 28 Jun 2025 at 12:04pm |
1952 CA13092
I have actually had this happen with poor contacts inside the switch
My Fluke 88 meter will record Min/Max readings and would pick up a momentary disconnect; just watching the meter probably would not be noticeable though. I do have an oscilloscope too ![]() |
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11974 |
Hi Guys! Just getting on here this evening. Haven't been on in a while. Been pretty busy in the shop. Gary, if your still having problems with that Tractor, I can tell ya it ain't the Distributor that's fir' sure! That unit didn't miss a beat on the last run test on the 504. I ironed the couple issues out with that. You have another problem there. Maybe a sticky valve when running. Higher rpms the valve may not stick. Lower rpms it starts to hang up and cause a dead miss. Gotta' be something with the Tractor. Possibly a fuel issue. A lean condition off idle till you get into the enrichment circuit, then it runs better and the miss is gone because it has a fatter mix and runs good under load. It's gotta' be somethin' like that. Steve@B&B
Seems doubtful that it would be valves. It had a complete, professional shop valve job. Compression seems reasonably good. The operating symptoms date back to the 80s or 90s (per my brother). It isn't something new. In the 80s, it had an automotive style toggle switch for ignition. Same symptoms. The key switch is new, the wiring hardness is 100% new. It is burning very rich at all RPMs, but not enough for visible black smoke except under load. It was burning leaner when I had installed the incorrect venturi (smaller diameter) in the carb last month. When I installed the new, correct venturi, it is again blowing black specks of carbon onto the hood. So, about the only thing left in common that hasn't been changed is the carburetor itself. It has been thoroughly cleaned and all jets verified open, but the main jet was not changed because the screw driver slot was severely damaged and I didn't have a super tiny easy out (plus it's at a weird angle and not sure I can get to it). I wanted to keep a TSX 486 carb on it and not switch to a Zenith, but I didn't find a source that I trusted so far. I'll perform a few more ignition checks in July (e.g. direct wiring battery to coil, direct ground wire distributor to chassis, perhaps oscope some signals). The GTC 505 provides oscope features but only for the high voltage signals. Seems like slightly short sighted design. Anyway, I've been wanting to get a small portable oscope for some time (they're pretty cheap now). My Tektronix 536 weighs about 500lbs and is a pain in the butt to move around. I should have done some of that low voltage signal testing this last trip but I wanted to get it out in the field and use it some (the fun stuff) :) The main glitches with that was the PTO shaft guard kept pulling too hard and stretching the chain clips (brand new it was very hard to turn in spots because it was severely warped), and on one occasion, the hydraulics would not go down (perhaps the hold valve stuck). The rest of the trip was spent raising the tree canopy around the yard to make it easier to mow. ~1 acre, 39 acres to go...I lost 6 pounds :)
Edited by dfwallis - 29 Jun 2025 at 1:28pm |
1952 CA13092
Those are excellent compression numbers; this does not eliminate the possibility of sticky valve guides though, or too tight valve lash, thus the recommendation for vacuum gauge testing.
Assuming the correct size of jet(s) then the fuel level in the float bowl must be too high; perhaps the float isn't floating?
We set valve clearance at .012. Doesn't mean it stayed at .012. We had plans to recheck it at some point. Maybe when it cools down a bit in the fall. Needs to be done, regardless. I don't know that it was blowing carbon specks in the 80s. He only said it was misfiring similarly. It did not misfire the last I used it before then, but started at some point and continues to this day, regardless of nearly everything being overhauled to spec to the best of our and the machine shops ability. I checked float level this week. It was as close to 9/32s as I could measure. The float does not leak. It is dry as a bone. I've checked it a dozen times. I inspected the carburetor pretty carefully. I saw no obvious cracks or leaks beside the one I sealed that was leaking fuel from the bowl at a very slow rate (the screw (plug) at the bottom front of the bowl). I've ordered some tiny easy outs to try to fix it correctly. All jets were replaced except the one at the bottom rear of the bowl. There was no screwdriver slot material left to latch on to. But, just because I express doubts about a particular cause, it does not mean that I've ruled ANYTHING out. Until it's resolved, everything is suspect. I've ordered a new portable oscope that should allow me to actually correlate the points signal with the resulting spark of the secondary, Ch1 vs Ch2 (10000x reduction probe).
Edited by dfwallis - 29 Jun 2025 at 8:56pm |
1952 CA13092
New manifold looks like it has a flat that could be drilled/tapped to provide a vacuum gauge attachment point. Don't think I want to do that. Not finding a good attachment option.
Edit: I found a pic of an original manifold and it appears to have a pipe plug at that same flat spot. If I were to drill and tap it I'd want to take it off so that I could clamp it to the drill press to drill a nice straight hole. Not ready to do that at this point. Edited by dfwallis - 29 Jun 2025 at 10:22pm |
1952 CA13092
Bummer. A vacuum gauge is a valuable troubleshooting tool. I put a new manifold on my Model C a couple years ago and it had a small pipe plug that we pulled out to run the old Surge milking machine.
I just re-read this whole thread to try to cipher out what we have all missed ![]()
I found no mention in this thread of re-torquing the head, re-setting the valves, replacing spark plugs, or re-tightening the manifold bolts since the rebuild; you have added a few hours since that post
This one is somewhat puzzling. At what RPM was this noted? At low idle there should be no advance, and at high idle it should be at full advance. I can see it bouncing around at mid-range while it is still partway advanced though. |
That wouldn't have Champion Spark Plugs in it would it? I've seen and heard of so many goofy issues with them things. Screw in a real set of plugs like NGK's or Autolites and all the Gremlins go away..... Black carbon specs on the hood? Hmmmm.... Steve@B&B
jvin248 ![]() Silver Level ![]() ![]() Joined: 17 Jan 2022 Location: Detroit Points: 437 |
Leaks at the manifold to motor interface can cause fuel to air mixture leaks. My WD ran better after I replaced the factory manifold it came to me with with a new one plus new seals as two exhaust leaked and I think one intake with a slight leak. I bought one of the small harbor freight ultrasonic cleaners and have run at least four antique carbs through it for much improved operation. Split the carb and open sides down. That may be better than the easy out game. Verify the coil you have uses an internal resistor not external block and is the correct coil for the voltage you are set at. External resistor blocks and wiring makes for more connections that can go bad/corrode. Are you getting intermittent shorts in wiring? Are the misses frequent enough you can pull a plug wire and isolate the cylinder it happens to? . |
Six videos have been uploaded to https://www.youtube.com/@OrangeAcres-h2k
These are under the playlist "misfire analysis". They will go public around midnight 1 July (CST).
1952 CA13092
It isn't a single cylinder misfiring. It is all of them at different times. I've searched for intermittent shorts, intermittent opens, gremlins...The new 6V coil has no external resistor. I switched it out and it made no difference. I've switched everything out related to the distributor, wires, plugs, points, rotor (3 different ones), cap (3 different ones), distributor partial rebuild (not the dust cap). No manifold leaks (and brand new).
1952 CA13092
Theyre autolite. I know there is a carburetor issue. GTC 505 was showing electrical issues, that's where I started first. I still haven't ruled electrical out. GTC 505 and timing light still show electrical dropouts. You can see them better on the long duration recording than on the single trigger waveform. But they happen at all 4 cylinders, not just one. But the analyzer is easily confused by proximity of other HV wires so I'm not 100% confident in my interpretation. I plan to try to find some high impedance tubing to wrap the wires in to improve it a bit. It says you need 2 inches of clearance, but that's hard to do coming right out of the distributor.
1952 CA13092
Page <123 |
