CA Clutch Installation |
davefullmert
Joined: 27 Dec 2010 Location: McKenzie, TN Points: 8 |
Topic: CA Clutch InstallationPosted: 05 Apr 2016 at 1:55pm |
I just split my CA because I ran out of adjustment on releasing the clutch. Sure enough, my fingers on the clutch plate are showing lots of wear. 5 years ago when I had the tractor split before I did not replace anything except the disk. I think that was a big mistake.
At any rate, I have a new clutch kit for the 8 1/2 inch this one requires. Included in the kit is a new release bearing. After removing my old one, I looks like I may need to press the old one out of the assembly. Is that correct? Also, once I have the new parts installed, is there some trick to setting the adjustment of the pedal or is it just a trial and error until the pedal travel is right? Thanks for all you experts out there. Dave |
Dave Fullmer
McKenzie, TN |
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 05 Apr 2016 at 4:39pm |
That's about it, unless you have excessive wear in the linkage. Then you'd probably want to build up the worn spots. It would make everything work together better. I don't remember what the free travel should be set at but someone chime in on that. Leon R Cmo
davefullmert
Posted: 05 Apr 2016 at 5:06pm |
Thanks Leon,
So my main question is do I have to press out the old release bearing from the casting? |
Dave Fullmer
McKenzie, TN |
davefullmert
Posted: 05 Apr 2016 at 5:07pm |
I don't really see any excessive wear in the pedal linkage. Also, I am not sure how to remove the old pilot bearing.
Dave Fullmer
McKenzie, TN |
davefullmert
Posted: 05 Apr 2016 at 5:59pm |
Well, I just took an other look, there is no way it could be pressed out so I just took a hammer to it and tapped it off the housing. It didn't take much tapping and now the old throwout bearing is off the housing. When the kit comes, it looks like a carefull tapping back on will do it. I also checked the grease zerk for accepting of grease and that is OK also.
Just a matter of waiting for the parts to put it back together now. |
Dave Fullmer
McKenzie, TN |
CTuckerNWIL
Posted: 05 Apr 2016 at 6:03pm |
Rick is the go to guy as far as I'm concerned on clutches and brakes.
grinder220
Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2375 |
Posted: 05 Apr 2016 at 6:14pm |
davefullmert
Posted: 05 Apr 2016 at 8:55pm |
Do I dare use the alignment tool for that? Or would mess up the tool?
Dave Fullmer
McKenzie, TN |
LeonR2013
Posted: 05 Apr 2016 at 9:36pm |
Take the end of little womans kitchen broom, cut of what you need. She'll never notice. Leon R Cmo
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 06 Apr 2016 at 9:40am |
I've made a jig to bolt to the back of the engine after installing the clutch. Then I set the fingers to the jig and put the tractor back together. Perfect free play every time.
davefullmert
Posted: 06 Apr 2016 at 1:27pm |
Wait a minuet, you mean the fingers them self are adjustable? The only free play that I know of would be on the rod that connects to the foot pedal.
Dave Fullmer
McKenzie, TN |
LeonR2013
Posted: 06 Apr 2016 at 7:06pm |
Dave, if you have a Rockford clutch here you go. You want three threads to protrude thru. the clutch rod fork. Then check the clearance of the forks and turn the adjusting screw if needed so you get a 1/4" clearance on all of them with a tolerance .010". Measure at the end of the shift forks, and don't forget to tighten the lock nuts. Sounds easy doesn't it? Oh, you did find the inspection plate? Leon R Cmo
davefullmert
Posted: 07 Apr 2016 at 4:45pm |
No inspection plate on my CA. There is a 2 inch dia hole in the bottom of the housing right underneath the grease zerk, but I sure can't find any way to adjust the fingers once the tractor is together again. I would think the pressure plate would be factory set to be in parallel plane to the flywheel. Then turn the clutch pedal rod for the right clearance.
Dave Fullmer
McKenzie, TN |
