CA clutch adjustment
bigredneck61088 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredneck61088 Quote  Post ReplyReply Direct Link To This Post Topic: CA clutch adjustment
    Posted: 09 Jul 2018 at 5:43pm
My CA went back together after the new engine rebuild good but I am having a clutch issue...
I cannot get the clutch to disengage, I adjusted the pressure plate per manual at 1.5 inches. It got a new clutch and pressure plate, when the tractor is running I can’t get the clutch to disengage far enough to go in gear. I run out of the adjustment on the rod... this tractor has the 8.5 clutch kit, and the old one was same size, ordered new from Steiner tractor
Thinking the either old specs are not right for the new pressure plate, or something else is wrong, any ideas would be helpful thanks!
Edited by bigredneck61088 - 09 Jul 2018 at 5:44pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 6:37pm
Might be the throw out bearing or its mounting is worn and so not pushing the pressure plate arms far enough. The shop manual may have some hints.
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredneck61088 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 7:54pm
Forgot to mention there is a new throw out bearing in, ive checked the manual and it seems I have way more than 1/4 between clutch and throwout
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2018 at 7:11am
How well did it go together? Any issues at all? A bent disc will throw those fingers down and when you step in on the clutch pedal, the disc will move with the pressure plate, causing it to have a non release factor and will grind gears. Seen this happen hundreds of times. Also, if it is a new one, chances are it's from China and will NOT be set correctly and that might be your problem. Several possibilities here...Rick
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2018 at 8:44am
Split it back apart your clutch disk has the hub facing the wrong way.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2018 at 2:16pm
Maybe...maybe not. Those China clutches are bad about NOT working properly or being adjusted right in the first place. however, if you can't get it working no matter what you do, then you'll need to take it apart anyway. The spring cage of the disc goes towards the pressure plate...Rick
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2018 at 2:24pm
You could add a few more threads to the clutch rod. Just saying
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2018 at 5:03pm
Having the disc in backwards or bent doesn't have anything to do with lengthening the rod. I would start with adjusting the fingers first... Rick
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2018 at 7:13pm
I did a rebuild on ca once and had clutch problems much like yours. When I put the motor back to trans the brass pilot bearing was a little snug, just enough to drag a bit and make it hard to shift and would creep a bit with clutch depressed and in gear. After some time of letting the new pilot " bushing" wear in, it has worked fine for the last 10 years.
Not saying this is what's happening to yours, just another scenario.
Leon B Mo
This page was generated in 3.531 seconds.
