CA 3pt hitch
BV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BV Quote  Post ReplyReply Direct Link To This Post Topic: CA 3pt hitch
    Posted: 11 Feb 2018 at 8:01pm
Who has the best deal on a 3pt hitch for my CA, mine is the pin type and so is my 2 bottom plow, so what's my best option here and best deal? Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 1:42am
Keep your pin hich plow and look for other factory implements. A 3pt on a CA is a giant step backward compared to the finest hitch system ever developed. If you must have a 3pt get a Ford. Any adapter or conversion you will get you’ll be disappointed with the total package. Nothing is harded to hook up and prone to geting mashed fingers and pulled muscles than a 3pt.
Edited by PaulB - 12 Feb 2018 at 1:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 5:33am
Gee Paul , tad might harsh on 3pt aren't you ? hmm...however truer words were never spoke !!! I've put 3pt to SC adapters on all my 3pt implements converting them to Snap Coupler ones to make life EASY and safer ! Each one has it's own top link BOLTED to it ,so I don't have to adjust every time I mount something....
The ONLY way I've found 3pt almost easy is when everything is on a concrete pad. Still a pain though.
BTW My CA was a SC version never had a pin type but should be easy enough to make an adapter or 2.
Jay
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 10:35am
I'll be happy to explain the hitches we sell (and use).  If you are comparing a snap coupler setup to a 3 point, then I agree.  Pin hitch to 3 point I disagree. But we each have our experience.
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 12:48pm
Made a three point hitch for D 14.If you can not man handle the implement to hook it up you better get you a prize pole because you will need it.
