c transmission question
Richmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richmar Quote  Post ReplyReply Direct Link To This Post Topic: c transmission question
    Posted: 21 Mar 2023 at 11:42am
Is there a way to adjust the c transmission to keep it from sliding out of third , first and second work  okay. will not stay in third unless you hold it in.
Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 12:32pm
you can unbolt the ccover on the right side and look inside... The shift forks are attached to the plate, so it takes some effort to reinstall....... Look inside and you will see the worn gears and dogs that engage..... Probably need to disassemble to repair... very seldom is it something simple.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2023 at 7:00am
The spacers in the transmission are worn allowing the gears to move up and down, side to side.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richmar Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2023 at 9:32am
thank you!
 I didn't think it would be something simple.
Rich
