C Pedestal Stud, etc.
Runamuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Runamuck Quote  Post ReplyReply Direct Link To This Post Topic: C Pedestal Stud, etc.
    Posted: 30 Apr 2017 at 12:07pm
Been working on my '41 C alternator and removed the fan pulley to free up adjustment to get belt to fit. One of the studs that hold the front pedestal to the engine block has been broken off since before I owned it. Does anyone know where I can find a stud and the part number? Also may as well replace valve cover and oil pan gaskets that are leaking, and radiator hoses. Is there one place that has all this? Haven't been able to find anything on the stud. Also need governor spring for '48 C.
Thanks, Bill.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 1:14pm
You can use a 1/2" grade 5 or 8 bolt. The studs are 1/2" curse thread into the block with 1/2" fine thread on the outside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Runamuck Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 1:39pm
Thanks, Dick. That should work, I guess. Didn't even think about that!
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2017 at 4:29pm
Rear axle stud from a truck works too.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2017 at 7:18am
Got it all including the special nut on the stud.
