C allis chalmers oil pressure bypass
Monte Mahan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Monte Mahan Quote  Post ReplyReply Direct Link To This Post Topic: C allis chalmers oil pressure bypass
    Posted: 10 Feb 2022 at 7:04pm
reading in my manual there is an oil pressure bypass thet limits the pressure to 15 pounds.  It isn't in the oil pump,  where is it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2022 at 7:16pm
the pump pushes oil down a hollow cam shaft to spray on the internal parts... there is a 1/4 inch TUBE that comes out of the flywheel housing and goes up to the FILTER BASE.. The filter allows about 15% of the total pump output to go thru, then DUMPS TO SUMP.. About 85% of teh pump oil goes to lube things and does NOT go thru the filter first.
The filter has to be Packed Cotton type and RESTRICTS the oil flow thru it.. There is also a 1/8 inch orifice tube inside the filter housing that restricts the flow... If you leave something out and the RESTRICTION is reduced,  too much flow will go thru the filter and starve the rest of the engine.
there is also a spring loaded PLUG at the front end of the hollow cam shaft that allows some oil to DUMP into the front gear train area... The backpressure from the spring and plug help to control the 15 psi pump output.
Edited by steve(ill) - 10 Feb 2022 at 7:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Monte Mahan Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 6:49am
Steve. Thank's so much for you're detailed explanation about the oil system.  I have lost oil pressure.  I'm guessing I either spun a  main bearing or the bypass stuck open.
juniorp53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorp53 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 8:26am
had pressure and lost it ....or never had it ?  tell us more!
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 8:36am
The oil pump sometimes will lose prime. Take the oil filter off, squirt oil in the upright tube. A little air pressure will help. With the filter off turn the engine or start it for a short time. Oil will come out the tube.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 8:40am
Did you change the filter ?  Is the 1/4 inch tube with the 1/8 inch orifice up the middle of the filter?  Take the filter off and crank the motor and see if any oil comes up out of the small tube..
At 1500 rpm do you have pressure, just not at idle ?  Remove the oil pressure gauge and crank and see what you get out..  This engine will run with 5 psi of pressure.. 15 is GREAT, but it will run with less... Did the GAUGE fail ?
It is possible for the pump to loose prime.  The 1/4 inch pipe that comes up out of the bell housing, you can open and pump a cup of oil down the tube with a squirt gun.. Its possible the motor sat too long and the oil drained out of the pump ?
Look at the oil on the dip stick ?  Old oil ?  Maybe time to change it out ? .. You can also drop the oil pan and inspect the suction screen.
My LAST choice would be bearing wear.
Edited by steve(ill) - 11 Feb 2022 at 8:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Monte Mahan Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 8:55am
Thanks for all the suggestion's.  Yes, I did have oil pressure after the overhaul.  I did pull oil filter to put seal ring under filter (Dumb mistake)  after that, no oil pressure.  Reading thru a bunch of posts, I think I have lost prime.  I will check that ball in the rotor and use some plastigauge to check pump end clearance.  the veins and springs look good.  Is losing prime a normal ting when changing the filter, if so I wonder how many motors have been ruined by this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 9:05am
It is not common, but it does happen.. Normally after setting for months. Sometimes you can reprime, and it never happens again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorp53 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 9:16am
those pistol grip oil can come in mighty handy for filling those lines with oil. the check ball is just a 5/16 ball bearing   and i am sure you found all the posts about the oil filters. then there is that cork ends in the rocker shaft ...#5 sealing cork found in hardware section at lowes.  its my understanding  that if it keep loosing prime the check ball is not sealing but steve would know more about that then myself
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 9:20am
junior is right about the ball.. Make sure the SEAT is clean... Sometims setting the ball on the seat and bumping with a brass rod and hammer will "reseat" an old seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Monte Mahan Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 10:12am
  Thanks every one who replied.  I will check all the suggestions.  watching video, my end play seams excessive, will check with dial indicator and probably go back with only 1  .004 gasket, my old one checks out to be .008.  I ordered new gaskets, expensive little burgers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 12:24pm
YES... with excessive clearance around the pump vanes, you can drain back to sump.
Suppose to be as tight as possible without touching... .002- 4 would be acceptable.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 2:45pm
Also, make sure the stand-pipe that goes from the filter base up into the hole in the middle of the filter is in place. It's not uncommon for the pipe to come out when removing the old oil filter.
This page was generated in 0.344 seconds.
