Bushing for Model B crank opening? |
Tgtack
Topic: Bushing for Model B crank opening?Posted: 30 Apr 2019 at 11:24am |
My 1939 B is a crank start only model. I have no desire to change that, but it does bug me that the crank handle basically rubs up against the nose sheet metal Everytime it is cranked over. I was wondering if anyone has done anything to protect the metal and the finish?
I have ordered a crank hole casting in brass that is originally for the model G and I am looking to fit it on to the B. What are your thoughts? Anyone done this or something similar? ![]()
1939 AC Model B, 1952 AC Model G, Case 195, numerous Wheel Horse, Hit Miss Engines, currently looking for a AC B10 garden tractor
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 30 Apr 2019 at 3:27pm |
They came with a flat metal piece spot welded on the inside. Most of mine were wore thru by the time I bought the tractor. I like the idea of the G part being used.
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8662 |
Posted: 30 Apr 2019 at 3:29pm |
That looks like a great idea!
Regards, Chris
HD6GTOM
Posted: 30 Apr 2019 at 4:09pm |
Looks like a great idea. Make sure the crank for your B will fit thru it.
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8485 |
Posted: 30 Apr 2019 at 4:11pm |
I, too, think it's a good idea. Mine is a little egged out from years of cranking.
Wdtractorman
Posted: 30 Apr 2019 at 9:01pm |
I can get 1/2 in steel from work. I was going to cut out a plate to go on radiator mounting bracket to see if it help. That the problem on mine anyway that hole is worn way out oblong.
Norm Meinert
Joined: 31 Oct 2010 Location: Davis illinois Points: 470 |
Posted: 30 Apr 2019 at 10:07pm |
call Mark at 440-570-3653 he has new part to weld on like the original.
Tgtack
Posted: 02 May 2019 at 9:37pm |
Got the bushing in today, crank handle fits fine. Will have to open up the hole some on each side to fit the oblong shape of the casting.
Tgtack
Posted: 05 May 2019 at 9:31pm |
Today I opened up the crank opening on my Model B and fitted the brass Model G bushing to it. Fits pretty good, now need to cut s gasket to fit under it and find some mounting hardware. Think it's going to work pretty good.
CrestonM
Posted: 05 May 2019 at 11:33pm |
Are you going to mount it on the outside or inside of the shell?
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2400 |
Posted: 06 May 2019 at 7:09am |
Just what I was going to ask. You could rivet in place with the fitting on the inside and it'd hardly be noticeable.
WC, CA, D14, WD45
Tgtack
Posted: 06 May 2019 at 9:49am |
Inside mounting poses another set of issues, one, the lip of the expanded metal would be in the way. Mounting without the flange covering the opening would also require a lot of rework of the opening and a refinish of the shell. Since I am not sure of the color yet (know the brand), I do not want to venture into a repaint till maybe this fall. If I can identify the color, then I am going to rework some additional area of the shell including replacement of the mesh, and at that time If I could find a damaged Model G tail section and cut out the stamped area, it could be grafted into the B shell to mount it as is mounted on the G.
Edited by Tgtack - 06 May 2019 at 9:50am |
Dick L
Posted: 06 May 2019 at 5:08pm |
Paint it orange and it will only be noticed by those that claim to be correct police. When I was pulling and had to put the C in a line of show tractors to qualify for the pull I had a big time setting back and listen to the correct police wondering if Allis ever put a straight drawbar on a C.
A picture for those that had not seen it posted before. One of a kind Lemmon drawbar set for pulling at 13 inches from the ground. ![]() Edited by Dick L - 06 May 2019 at 5:17pm |
Tgtack
Posted: 06 May 2019 at 10:19pm |
Finished up installing the Model G brass crank hole flange and the B is now all buttoned back up. Works great, no more rubbing off the crank handle against the grill sheet metal. While I had the tin work off, touched up the black paint on the engine components and manifold. Instead of webbing between the metal joints, I used a heavy gauge clear mylar tape that I have used on the tin work of garden tractors with good results. Is heavy enough and has enough lubricity to prevent chaffing. I did use a piece of orange webbing under the hood/tank body strap.
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 07 May 2019 at 5:15am |
Looks mighty good. Now scrub up your floors.
HoughMade
Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 720 |
Posted: 07 May 2019 at 10:26am |
Seeing this, I'm thinking of getting one....any my B doesn't even have a crank pulley that allows for the use of a crank.
1951 B
