Built a weight stack for my WD45
KC-WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Built a weight stack for my WD45
    Posted: 30 Mar 2012 at 9:13am
I work for a bridge construction company and got (5) 60lb bearing shimms from a bridge that we were doing some structural rehab on. I thought they would make a pretty good front weight stack for my WD45 that has a habbit of getting a little light in the front when plowing. I got them home and sand blasted the old paint off and sprayed them black then made a couple brackets out of 4" angle iron and 5/8" all thread. I think it turned out pretty good. How much weight do you guys put on your tractors?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 9:17am
3/4" all thread I ment to say.
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 9:40am
I have always seen 4 of the allis slab weights used(or more) and they are 70 to 75lbs. So thats about right. By the way it looks good and a little bit of grill protection to boot.
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 9:44am
Looking good...when I saw the front on pic I thought you might be 'closing off' the grill from wind but the side view shows that your radiator will not suffer from lack of wind.
Nice add.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 9:53am
Good job!  You could use Allis 75 lb slab weights from the "Hundred" series to do that as well.  I use four "Hundred" series weights on a home built bracket on my D17 Series IV except that they stack out horizontally not vertically.  Mike
Edited by Skyhighballoon(MO) - 30 Mar 2012 at 10:01am
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 9:57am
Thanks! I when I found those, with predrilled holes that all lined up and free to boot, I thought it must be my lucky day. I should have bought a power ball ticket!
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 11:17am
In one of the pictures it looks like the top bolt is missing a lockwasher and is not firm against the front plate.  All three of those need to be tight or you will wind up breaking out a bolt hole.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 11:48am
Looks nice. If you come by any more of them, just kick them out at Holt, Mo.  Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 12:51pm
I had read somewhere that you shouldn't put the 'slab' weights on a W/F ?  Yes or no?
