Buda engine parts
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Topic: Buda engine parts
    Posted: Yesterday at 10:36am
I understand Buda parts take some hunting to find at best. Son inlaw is thinking of working on his dads early HD 6. It needs a complete engine overhaul, possible a crank and cam shaft. Is this one of those that parts are worth 2 or 3 times the worth of a running tractor. I don't think there is that much family history in this tractor.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 12:20pm
I would start with grindstaff in Missouri
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 12:33pm
HD6 depending on the year didn't have a Buda, it had an Allis Chalmers based on the Buda design, there is a difference.  The very first ones might have had Buda that were left over after the buy out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 45 minutes ago at 10:11am
They have 2 HD 6's and the other one is the latter model. So they know the difference. So I was curious of what others thought about parts. As I asked just hard to find or almost nonexistent and very expensive.
They seem to get into expensive/hard to find parts projects. Have had a IH TD 9 spread across their shop for 3 or 4 years. Needs one piston and sleeve. The only source of new they have found is $3500 per whole. I have found them a local source of used. But probably need to take the whole tractor. But way less than $3500.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 20 minutes ago at 12:36pm
Gotta know when to say when.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 25 minutes ago at 3:31pm
I have a complete late model engine for an HD6 Id sell for $3500. its old stock but never ran
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 20 minutes ago at 3:36pm
i sent the cam to my d262 engine to delta cams in washington they had to weld one journal and one lobe and regrind all the lobes and lifters everything it was about 200$
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 23 minutes ago at 4:33pm
I have for HD6  3 or 4 used crankshafts some cam shafts and more but am located in CANADA and my place is closed until april
This page was generated in 0.531 seconds.
