Brush hog blades |
cosborn
Joined: 21 Feb 2013 Location: bourbon co. ks Points: 345 |
Topic: Brush hog bladesPosted: 12 May 2016 at 7:49pm |
I broke a blade on my Sun master rotary mower by Sunflower industries, modal ca-160d and am having trouble finding a replacement.
Any suggestions? |
1949 "C" vin #c71215, 1939 "B" Wide front, WD45 nf, WD45 wf, 1941 "C" work in progress. Wd wide front
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4874 |
Posted: 12 May 2016 at 9:31pm |
I broke a blade on a Bushhog, the price on line or the local Bushhog dealer was about the same no shipping from the local dealer. This mower is old and I thought I mite have trouble but was very easy. But Bushhog is still in business which helps too.Good luck.
Edited by Ray54 - 12 May 2016 at 9:33pm |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55290 |
Posted: 13 May 2016 at 5:01am |
Take a good blade and go shopping at TSC. Should be able to match it up, if they have it in stock. If not, take measurements and go on the innernut to Shoup or tisco...
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 13 May 2016 at 7:32am |
Buy two sets. If it broke once then it will again. I always keep a spare set sharpened and hanging on the wall just in case.
1957 WD45 dad's first AC
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 13 May 2016 at 9:12am |
a lot of farm stores are starting to carry generic ones, if you know the size you can check locally first, if close, maybe a machine shop can cut one down to size? I had an old Sunmaster, and found new blades for it years ago, but the rest of the mower wore out/broke before I could get them changed.
Creek Jenkins
Joined: 14 Sep 2009 Location: Northern Minn Points: 812 |
Posted: 13 May 2016 at 11:09am |
Sunmastr is now owned by Art's Way, they still sell parts but can be a bit pricey. The original blades on mine were really soft, they bent easily when hitting small rocks or wood chunks, I bought a new set, can't remember where.. New blades are really hard, been running for grass cutting 3 years now haven't bent one yet on the occasional rock or stump. They are a bit strange as no center hole, just two holes either side of center.
ASAP Tractor parts has a blade that looks like mine, for a 60" deck: •Replaces Arts-Way OEM nos R66103 •Length: 21-5/8" •Rotation: CW •Width: 3" •Thickness: 3/16" •Bolt Holes Diameter: 1/2" cheers, Creek |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 13 May 2016 at 11:48am |
Agri-Supply would be my first place to try. if you go to TSC they'll tell you Tough $hit Charlie
