Brake conversion on a B questions.
skeeters65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Topic: Brake conversion on a B questions.
    Posted: 19 Jul 2015 at 8:16am
Just curious if it is possible to convert an older hand brake tractor to the newer foot brakes?
Thanks
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2015 at 8:34am
I converted my hand brake C to foot brakes. It was easiest to buy a tractor with no engine, rounding up the parts one at a time will get expensive and it's a bolt on job.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2015 at 8:45am
Thanks
I have converted several hand brake B's to foot brakes. I have bought the side fender rails, foot levers and the top break band lever assembly's from a C. I clamped the B side rails to the C rails and cut off the top with a torch and ground the top of the rails smooth. It all goes back together as easy as it comes apart.
1939Dodge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2015 at 2:13pm
My 1939 B was modified with a set of foot pedals that push on pushrods attached to the handles. Looks terrible, but it was cheap and it works.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2015 at 3:27pm
I probably have all the C foot brake parts for anyone wanting to do a hand brake B to foot brake conversion as described by Dick L using cheaper C parts. Hardest part about using the C fender supports is cutting them down to B size.
