Bought a 2500 disc
AdamA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Topic: Bought a 2500 disc
    Posted: 07 Jan 2012 at 3:15pm
Just got home from the auction w/a very nice 20' 2500 disc, shedded, very good tires,excellent original paint and cyls,no leaks or bearings out....two broken discs....whats it worth?? paid $1400....no idea what the going price is....
57'D-17,78'185,83'6080,76'7040,84'8030 FWA.02'Dodge cummins
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 4:31pm
Adam you got a great deal I would say. Last auction I missed had a 12 footer nice shape but needed paint brought 1300$ and that was a great deal I thought cause the dealer was askin 2000$ prior to the auction.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 6:05pm
Adam, you got a great deal on that one!! Can you post photos?? Any other orange toys there? Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 6:45pm
yea I'll get some pics tomorrow,no other orange, disc was the only thing...they had been pulling it w/a 9700 ford
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 7:20pm
Good deal !! Seen one a while back faded paint but good blades, no welds etc for $1200
frankmi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankmi Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 9:27pm
Center fold or wing fold?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 7:19am
centerfold
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankmi Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 6:21pm
Something you may want to look for or change. On my 2500 center fold, had problem with frame breaking on main frame where lift cylinder mounts and gang channels are mounted. Holes drilled thru main frame to adjust angle of gangs weakens frame causing frame to break because pressure of lifting and weakening of frame due to holes. Mine had been welded several times but kept on splitting behind or ahead or thru reinforcements. You may want to cure this condition by welding heavy angle iron to side of main frame with holes drilled thru it to change angle of gangs, angle iron will also help stiffen frame in this area! Mine is broken so bad and the rest of the frame is sprung so bad that it may not be able to be fixed with out being completly cut apart and new metal fabricated and cylinder attachment made! 2600 center folds are made with angle iron adjustments. Did'nt know this untill I was looking for a used frame for mine!      frankmi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 7:44pm
Thanks for the Heads up! this one looks good so far no welds or breaks but may reinforce it anyway while its still that way!
