block comparison-844 vs 731
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Topic: block comparison-844 vs 731
    Posted: 13 Apr 2012 at 9:17pm
I suspect I know the answer but here goes. Can a block from an Allis 844 engine be used to replace a block from a 731 Allis engine.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 9:45pm
if your referring to the engine use in 8550 and 4W305 then i would say yes.  major differences should be in crank (stroke) and compression height of pistons and maby rods not sure.  otherwise only minor differences like exhaust manifolds (731 has 2) for twin turbo and different turbo piping.  intake manifold maby be different for turbo piping also.
this would apply to later 844 blocks like 17000-25000 motors.  early 16000 and 21000 and buda 844 blocks have smaller main journals.  My 59 HD16 has 16000 and bearings are not available
 i think the blocks are identical, hopefully some one who knows for sure will chime in.
 the 731 is just a destroked 844
Edited by CAL(KS) - 13 Apr 2012 at 10:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 9:48pm
I would guess ( and it is only a guess) that if they were both built new at the same time in history, they would be the same.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2012 at 9:04am
I have a block , 731 , out of an 8550 . Cheap.
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2012 at 6:26pm
Might be interested in that. Can you PM me of the price and details. Thanks
