biodiesel gunk in fuel tank
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: biodiesel gunk in fuel tank
    Posted: 13 Jul 2015 at 5:04pm
So my MM Vista G1000 aka "Big Mo Nasty" has been sitting for 2 years with bio-diesel in the tank waiting for me to replace a scored piston. I'm currently working on getting it back up and running and need to get the gunk out of the tank. Any suggestions? Its a 52 gallon tank with a fill hole the size off a WD or D17 so there isn't a whole lot of room to work with there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2015 at 5:20pm
without knowing/seeing the tractor....
could you use one of those 'diesel fuel' rated 12 volt 'transfer' pumps to suck it out into TWO 45 gallon drums ?
I might be tempted to siphon it but... a pump sounds a whole lot better and safer !
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2015 at 5:24pm
I already pumped all the fuel out but the gunk which is like sticky tar is stuck to the bottom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2015 at 5:43pm
I have used a steam cleaner to wash out fuel tanks before. You also could try some E85. It's eats Biodiesel growth. I got a few injection pumps to work again after running E85 through them. Matt
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2015 at 5:49pm
I done this on an XT last winter, put a few gallons of lacquer thinner in it, slosh it around, let set a few days then power wash it out,, be good as new
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2015 at 10:57pm
    Get a "SMALL" can of carb and choke cleaner, spray a little bit into the tank and let drain. Instant gratification .
Edited by Auntwayne - 13 Jul 2015 at 10:58pm
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2015 at 12:37am
I used E 85 on a Hesston crawler (Fiat) tank, took several batches but finally got it clean.  Learned the hard way to only use bio diesel in the summer and then run off road diesel for the last couple tanks.  Or drain the tank at the end of the season before it has a chance to gunk up.  Good luck!
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2015 at 6:58am
Think I'll give the E85 and a pressure washer a try. Thanks for the tips
