Best way to tap………..
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Best way to tap………..
    Posted: 29 Apr 2025 at 7:05pm
into PEX(3/4”), with cpvc. I don’t have a pex crimper, or any pex tools for that matter. Never worked with pex before. This will be a hot water extension from bathroom supply to laundry room. Or, would I be better off using pex, and getting the crimping tool, and stuff. The pex in the home is the blue(cold) and red(hot) TIA.
Edited by Lars(wi) - 29 Apr 2025 at 7:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2025 at 8:15pm
Shark bite fitting will easily connect the 2 . Be sure and use the plastic insert that comes with the fitting on the pex side . You don't need it on the cpvc side.
Edited by Pat the Plumber CIL - 30 Apr 2025 at 7:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2025 at 8:36pm
forget the CPVC... nothing but problems when it get OLD and BRITTLE, or froze... the PEX works great... I have a crimper and go that route.. Have used a couple shark bits and they are easy..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2025 at 8:41pm
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2025 at 6:19am
When we had our second well put in at the farm the guy told me he never uses PVC anymore. Everything he does is PEX because of its ease of use
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2025 at 6:34am
I've not had any problems with CPVC getting brittle with age myself but it's never ran where it can move other than normal thermal expansion in the hot water lines. Replumbed my house complete in 1990 replacing the old galvanized steel piping then and I've had to modify the lineset for new water heater installs four or five times since for new appliances.
Floor heat in my shop is PEX and about 25 years old without problems I know of, but it's under 8" of concrete so kinda hard to see.....
That's All Folks!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 4 minutes ago at 1:41am
Get a pex crimper, a ring breaker, some fittings and PEX.
Cut the pex mostly square.  Slip a crimp ring over, stuff a fitting into it, slide the ring over, put the crimpers on, squeeze 'em full-shut, and you're done.
If you make an error, or need to make a change, the ring breaker will allow you to cut off the old fitting, snip off any extra tubing, slip the breaker in over the ring, squeeze, rotate 180, squeeze, and the ring will break off, freeing the fitting for re-use.
