Best black muffler paint? |
Brian(Va)
Joined: 16 Sep 2009 Location: Red House, VA Points: 91 |
Topic: Best black muffler paint?Posted: 21 Mar 2018 at 5:15pm |
Needing to paint muffler on my 170 and D15, what is the best black paint for this? Thanks
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4812 |
Posted: 21 Mar 2018 at 6:34pm |
There is hi temp paint good to 2000 degrees. I think VHT is the brand I have used on headers and mufflers.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4072 |
Posted: 21 Mar 2018 at 6:52pm |
vht, one muffler one full can of paint but it stays on. if there is somthing better that can be done in the shop i would like to know
BEK
Joined: 05 Nov 2017 Location: Wilmington, NC Points: 216 |
Posted: 21 Mar 2018 at 7:33pm |
VHT. Carefully follow the curing instructions after you paint your muffler.
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2887 |
Posted: 21 Mar 2018 at 8:07pm |
Good heavens go to Lowes and buy some black grill paint. I did that years ago and still look good on my 6080.
Gerald J.
Posted: 21 Mar 2018 at 8:39pm |
I have a spray can of Ace Hardware Heat Resistant Paint. It says good for grills, muffler stacks, and manifolds among other things. Supposed to withstand 800 degrees F continuously and up to 1000 degrees F intermittently. Part number 17188, bar code says 17188 brown. I presume they have black, I want to use this to add details to a fiberglass door where the sun through a storm door has burned the paint off. Its dark brown.
12 ounce spray can says it covers 15 to 20 square feet. Gerald J. |
wbecker
Posted: 22 Mar 2018 at 12:02pm |
I have tried several special exhaust paints. I now use Rust-Oleum "High Heat", for Grills and Wood stoves, lasts far longer than anything else I have used.
Rick
Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3695 |
Posted: 22 Mar 2018 at 12:44pm |
What MR. Becker said...
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 22 Mar 2018 at 12:51pm |
What Rick said.
1957 WD45 dad's first AC
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 22 Mar 2018 at 2:09pm |
This ought to get a rise out of Shameless, but JD probably can't be beat, both heat and durability.
Gerald J.
Posted: 22 Mar 2018 at 4:44pm |
At the local hardware store I did see Rustoleum high heat in brush and spray can this afternoon.
Gerald J. |
drobCA
Joined: 20 Jun 2017 Location: Perris, CA Points: 292 |
Posted: 22 Mar 2018 at 8:34pm |
wrecker, rick, stan & me. rustoleum.
I found it best to bring it up to operating temp for a short time first time - seems to sorta "set" it. but then again, that might just be a subjective observation.
3 Ford 8N's I loan to neighbors, but the '52CA, '41B and little B1 I do not.
Gerald J.
Posted: 22 Mar 2018 at 8:41pm |
The instructions on the Ace spray can suggested setting the paint without getting as hot as it is supposed to withstand the first time.
Gerald J. |
Mike Kroupa
Joined: 02 Oct 2009 Location: pierce, ne Points: 344 |
Posted: 22 Mar 2018 at 8:54pm |
I'll second the JD black hi-temp paint, it's great stuff!
HudCo
Posted: 23 Mar 2018 at 9:57am |
all the barbequee paint and rustoulim last a little while used that stuff for years hook the diggers to it for five minets or in the rain working a little its gone . you can get vht from any parts store . we used rustolem barbequee black on the headers on my buddes pulling truck it was gone the first pull used the vht the last two years and has not burned at all. i will try any brand or kind at least once , every tractor that leaves our shop that has had the hood off gets the pipe painted and straightened because it seems like a lot come with a crooked pipe . so it leaves black or silver and straight and know that my customers like that little extra
