|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| Battery question |
| Post Reply   |
| TMiller/NC   Orange Level Access   Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |  Post Options  Thanks(0)  Quote  Reply  Topic: Battery question Posted: 30 Nov 2016 at 8:01pm |
   When I remove the + cable (which is ground) on my CA and connect a volt meter between the + battery post and the disconncected battery cable (ground) I read 6.xx volts.  Is this normal?   This is with light switch off and the key switch off. | |
| Gerald J.   Orange Level   Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Nov 2016 at 8:07pm |
   The volt meter is very sensitive, needs very little current, it is showing there is come current from the negative post to ground, but that can be literally a few microamps for a digital meter to read. Could be the current in damp dust, or a problem with the regulator or a switch. A test lamp makes a better test, even better if the lamp takes an amp to light. Then you can test the voltage across the lamp between the battery post and the ground cable. If there are several volts with the lamp in the circuit you need to find the load because it will discharge the battery in a while. Your meter probably has a current scale but its easily damaged by excess current at a minimum blowing a fuse inside but the damage can be greater if the current is too much for the circuits in the meter. Gerald J. | |
| TMiller/NC   Orange Level Access   Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Nov 2016 at 8:29pm |
   Thanks Gerald, I hadn't thought of putting an amp meter in series to check for amp draw. I am not getting any spark when removing the cable.  Digital meter has a 10 amp meter built in so I might try putting it in series.    Thanks, Tim | |
| DougS   Orange Level     Joined: 03 Nov 2011 Location: Iowa Points: 2490 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Nov 2016 at 8:46pm |
   Nooooo. Do it through way Gerald said. One wrong move doing it your way and poof goes the fuse in your meter. Many times those fuses are a bit unusual and very hard to find. I've checked leakage directly, but I always used an amp clamp device which isolated the meter. Edited by DougS - 30 Nov 2016 at 8:48pm | |
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
